boost and hp
Post Reply
AE101Z
boost and hp
Post by AE101Z »
does anyone know 1 bar= ? psi
and 1 hp = ? kw
thanks
Post by fivebob »
1 bar = 14.5psi
1hp = 0.746kw
GT4 20
Contact:
Post by GT4 20 »
1 BAR = 14.7psi
Silvertop
Post by Silvertop »
Nope, fivebob is right.
1 BAR = 14.50377 psi
Al
Contact:
Post by Al »
14.7psi is 1 atmosphere ;)
also if you wanna get technical, 1 kg/cm2 = 14.2 psi
TrouserFxGt
Post by TrouserFxGt »
SS II wrote:1 BAR = 14.7psi
a common misconception.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
EVLGTZ
Contact:
Post by EVLGTZ »
Al wrote:14.7psi is 1 atmosphere ;)
yes but 1 bar does not equal 1 kg/cm
also a common misconception :)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
Al
Contact:
Post by Al »
Yep :)
GT4 20
Contact:
Post by GT4 20 »
I consider myself corrected :oops:
:wink: Gary
Post by Adamal »
This is part of why I prefer N/A :)
Al
Contact:
Post by Al »
Adamal wrote:This is part of why I prefer N/A :)
I thought it was because you like going slow? :P
Post by fivebob »
In which case do you know the conversion between in.hg and kPa :P
http://www.simetric.co.uk/si_k.htm contains all the metric conversions you should need.
Silvertop
Post by Silvertop »
EVLGTZ wrote:yes but 1 bar does not equal 1 kg/cm
Yeah something like 1 BAR = 1.019 kg/cm²
1 BAR = 0.98 atmosphere
cm of mercury anyone? ;)
MrOizo
Toyspeed Legend
Contact:
Post by MrOizo »
Atmosphere = 76 cm Hg ;) (760 mm Hg
Jools
Contact:
Post by Jools »
Just download this people http://www.esbconsult.com/esbcalc/esbunitconv.html
Saves hurting your brain 8)
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Post Reply
