ae101 4agze extractors
Postby dimmy » Tue Jun 22, 2004 6:32 pm
hi im gettin some extractors for my ae101 4agze, and i was wondering if the ae92 gtz has the same outlet ??? and also if 20valve afermarket extractors wood fit, im planing on gettin a 4-2-1 setup if anyone knows please let me know
dimmy
Postby Bazda » Tue Jun 22, 2004 7:20 pm
all 4agze engines have to same pattern for the exhaust manifold.
20v ones are slightly different.
Postby dimmy » Wed Jun 23, 2004 7:22 pm
cheers ,
how different are the 20 valve? and also is it because of the extra 4 valves? do normal 4age extractors fit ?? :lol:
dimmy
Postby TRDWGN » Thu Jun 24, 2004 7:43 pm
20v factory extractors can be made to fit the 16v very easily the two most outer holes aren't in the same position, one end can be simply re-drilled and the other either slotted or weld a tab on and drill. no biggie!! although i am remaking the 2 to 1 piece as the std part is real ugly and i am sure it is restrictive!!
TRDWGN
Postby MetalupYoAss » Sat Jun 26, 2004 5:54 pm
i've got some 4>1 extractors to suit a 4agze, will give more power up top..
$100 auckland if your keen PM me
MetalupYoAss
Users browsing this forum: No registered users and 32 guests
