confused on st162..........
Postby LowRydr » Wed Jun 23, 2004 12:19 pm
hey im just looking at buying a st162, its a 1986 model and i have a 1988 model,
I havent seen the car inperson but.... it has a 2.0lt twin cam motor (i suspect its a 3sge...) and mine has a 3sge,
But my car is 5stud (5x100) and this car is clearly 4stud. now i thought all celicas (except maby the 4age ones) were 5 stud..
Or is it the GT-R's are 5 stud and the rest are 4? or that between the '86 and '88 models the stud pattern changed? i just wana know that if i buy this car will I be able to use the gear box, pedal box cv's .etc to bolt into my st162?
///TRD Toyota Racing Development
take a really hardcore project idear, making it a reality? .....im 70% there
LowRydr
Postby Twolitre » Wed Jun 23, 2004 1:44 pm
All 3SGE ST162's are 5 stud however the one you're looking at might be a 3SFE although all the manual stuff should be the same except for the flywheel maybe.
Twolitre
Postby Mr Revhead » Wed Jun 23, 2004 2:58 pm
after having a qwik look on the epc 3sge st162s have 5 stud and st160 (1s) have 4 aswell as st163 (4s)
i think some early (up to mid88) 3sfe ones have 4 stud as well... can be sure of one thing though... if its 4 stud it wont be a factory 3sge....
Postby LowRydr » Wed Jun 23, 2004 6:15 pm
ah well its usless to me then i suppose :s damn
LowRydr
Postby LowRydr » Fri Jun 25, 2004 9:12 am
you dont know for sure if the gear box, and flywheel etc are the same or interchangeable do you?
LowRydr
Postby Mr Revhead » Mon Jun 28, 2004 10:31 am
i dunno about being the same, would probably be diff ratios.
not sure about the flywheel either, if its got the same number of bolts then it probably interchangable
Postby LowRydr » Mon Jun 28, 2004 2:23 pm
ah its actually a st160 a and hes droped a 3sge into it. so im guessing suspension and everything is different
LowRydr
Postby Mr Revhead » Mon Jun 28, 2004 2:28 pm
yup itll be different
have you checked out that 4a box yet?
Postby DFECTED » Mon Jun 28, 2004 9:56 pm
4age celicas (AT160) are 5 stud too
DFECTED
Users browsing this forum: Bing [Bot] and 62 guests
