turbo 4age engine management
Postby low_rider » Wed Jun 30, 2004 8:27 pm
whats the cheapest way of running a turbo on a smallport 4age in an ae92 fxgt ,managment wise
i cant afford a afta market engine managment at the mo so whats the cheapest way
rulk
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
http://toyspeed.blakjak.net/profiles/profile.php?id=336
low_rider
Re: turbo 4age engine management
Postby Monsterbishi » Wed Jun 30, 2004 9:23 pm
low_rider wrote:whats the cheapest way of running a turbo on a smallport 4age in an ae92 fxgt ,managment wise
ae92 4agze ecu & loom & dli setup.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Stu- » Wed Jun 30, 2004 9:51 pm
Stock ecu if you foll around with it. Good for a couple of psi
Project Thread
Stu-
Postby low_rider » Wed Jun 30, 2004 10:09 pm
wat do you mean fool round with it i only wanna start with bout 6-7 psi
rulk
low_rider
Postby mister2 » Thu Jul 01, 2004 11:51 am
cheap = boom.
dont bother, its not worth the hassle of 'tricking' the stock ecu - talk to mrozio for the results of this.
turbolinks are about $500, powerlinks are cheaper, if you can't afford either of these you shouldnt be doing a turbo conversion.
nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
HERE HERE!!!
Postby ezy10s » Thu Jul 01, 2004 12:19 pm
nuf said on that me thinks.
if you cant afford to do it right- dont do it at all
Member #244
Gone fishing until further notice
ezy10s
Postby EVLGTZ » Thu Jul 01, 2004 12:19 pm
mister2 wrote:cheap = boom.
nick
actually using the std ecu is not a problem IF you know what you are doing and know the limits of this type of setup.
but yeah the turbolink and powerlink are good cheap options
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby low_rider » Thu Jul 01, 2004 5:09 pm
evl gtz do you know what you are doing?
could you do it for me
rulk
low_rider
Postby RedMist » Thu Jul 01, 2004 5:57 pm
[quote="low_rider"]wat do you mean fool round with it i only wanna start with bout 6-7 psi[/quote]
You have to think about your ultimate goal. Your going to run a 10.3:1 compression motor on boost? With a stock ECU? With no knock detection? 6-7PSI? BOOM BOOM BOOM BOOM BOOM.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
turboing ae92
Postby THA SHZ » Thu Jul 01, 2004 6:28 pm
AE92 levin map sensored , so you can use this easily for what you want and run standard computer someone on here had the loom for sale and sparten autowreckers has the computer for bout $190 . :D
THA SHZ
Postby suberimakuri » Thu Jul 01, 2004 7:42 pm
nothing wrong with the compression.
nothing wrong with no knock detection.
it's all in the fuel and spark.
suberimakuri
Postby matt dunn » Thu Jul 01, 2004 8:37 pm
nick
If you dont already have a loom or an ECU or a map sensor and have to byt all three then std way will be about the same as aftermarket and not as good in my opinion.
Matt
Postby low_rider » Thu Jul 01, 2004 10:16 pm
already have all 3 in car
rulk
low_rider
Postby Drifter4ag » Thu Jul 01, 2004 10:49 pm
redtop turbo is mean .. compression is the shiz .. dont let mutton limit your boost you must unlearn what you have learned to make true power
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby matt dunn » Fri Jul 02, 2004 12:24 am
low_rider wrote:already have all 3 in car
Do you have a supercharged ECU & sensor, cause wont run on non-supercharged one with boost.
If you do then your 1/2 way there already.
Postby suberimakuri » Fri Jul 02, 2004 1:09 am
shudup... yes it will.
suberimakuri
Postby EVLGTZ » Fri Jul 02, 2004 9:13 am
Karl_Skewes wrote:shudup... yes it will.
hehe of course it will 8)
EVLGTZ
EVLGTZ
Postby low_rider » Fri Jul 02, 2004 5:26 pm
evl gtz can u do it for me or tell me what to do :0
rulk
low_rider
Postby low_rider » Sat Jul 03, 2004 11:52 am
also wat about a apexi safc would that make it run a hell of alot betta
rulk
low_rider
Postby TWSTD » Sun Jul 04, 2004 10:24 am
If your car is MAP not AFM then you can do what i did when i turbo'd the AE115 carib. Replace the MAP sensor with a 2-BAR MR2 item and replace the injectors to suit. Now with the 7AFE engine the 2 bar MAP and starlet GT injectors provided a perfect fuel curve (as shown below). You will also need to knock back the timing. Best way to do this would be to use something like an MSD Boost timing master. PM me if u want help locating one - i can proabably get one in from the USA for you. With a 4AGE you may or may not be able to use the starlet GT injectors - its all about matching the voltage output on the MAP sensor to the increased flow thought the larger injectors - as the injector pulse never changes as the stock ECU has no idea you have put larger injectors in. In you are skeptical about this methodology go do some web searches - its done a lot in the USA.
Dyno sheet: Note fuel curve at the top.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
