heard that the blacktop crank is semi-hollow and a lot lighter but visually the same.
Dont know if it's true but if you've stripped them down you may be able to check
Mr Revhead wrote:heard that the blacktop crank is semi-hollow and a lot lighter but visually the same.
yeah the part numbers are the same with no supercessions right from the first redtops up to and including the blacktops. so all 4ages from redtop (and very late aw11) use the same crank
good job redmist, i think we should have a FAQ sectin where this kind of thing can be stored.....
ChaosAD wrote:Mr Revhead wrote:heard that the blacktop crank is semi-hollow and a lot lighter but visually the same.
So do you mean that all 4age/ze cranks with 42mm gudgeon pins are the same? I thought the silvertop crank was lighter than the redtop crank.
