WeirdGTi16 wrote:CV or constant velocity joints are a WOF requirement and yes you can be failed for a noisey / faulty jointStrictly speaking a split boot will not fail you but a good testing station / garage will note it on the wof sheet as this will lead to the ingress of dirt & water (as well as lose of grease) causing joint to fail in future
WOF's are after all a safety check to keep you and other users on the road Safe whan driving![]()
WeirdGTi16 wrote:hey "Dude"![]()
Information comes from working as a Mechanic on the shop floor for 10 years & a further 10 years in the Automotive Industry as a Parts Technical Product Specialist:!:![]()
Suggest you have alook in your "VIRM" section 10-2 Hubs & Axles.
As others have pointed out this is grey area and can go largely undetected. But if CV's are worn badly enough to effect steering or drive to front wheels they become a safety / vehicle fitness Issue !
