7AFE engine types
7AFE engine types
Postby matt dunn » Tue Jul 06, 2004 1:22 pm
Looking at doing a repower to replace a 5AFE that is stuffed and keen on a 1800 7AFE engine.
Are there a few different types?
I have been told there are models with and without a dist (multi-coil).
Does anyone know how many different types there are and what vehicles they came out in?
Matt
um...
Postby [TWZTID] » Tue Jul 06, 2004 10:16 pm
On the 'sticky' telling everybody that theres a link for every Toyota engine out there, says that the 7A-FE is twin cam, but I can only find 1 8O
I have 2 coil thingy's having 2 spark plug leads each on mine
(NOTE: Im not a mechanic)
[TWZTID]
Postby Lloyd » Tue Jul 06, 2004 10:47 pm
7A-FE is twin cam, thats what the F means
Not a lot on the net, but Celica kept showing up
CALDINA 7A-FE, 3S-FE, 3S-GTE 1996~
SPRINTER CARIB: AE 11 SERIES 4A-GE, 4A-FE, 7A-FE, 1600, 1800 1995~1998
Premio 4WD AT211 7A-FE 1800 1995-1999-
First, let me give you some background information on the 7A-FE in case you don't already know. The 7A-FE is the last in Toyota's great line of A-series engines. It is an inline-4, DOHC, 1762cc 16v MAP-based engine. The other (very) popular A-series engine is the 4A-GE, available in beauties such as the Corolla GTS, MR2, and Levin, with 16 or 20 valves, naturally aspirated or supercharged! The 4A-GE also powers all the race cars in the KOOL/Toyota Atlantic Championship, North America's premier open-wheel development series. The 7A-FE shares basically the same block as the 4A-GE, but with 200cc's more displacement (~1800cc vs. ~1600cc), the difference being in the stroke. The 7A-FE's bottom end isn't quite as strong as the 4A-GE's though. The 7A-FE connecting rod is longer and skinnier, and the crank is not forged. Another major difference between the 7A-FE and 4A-GE is the cylinder head. Toyota designates the "F" as meaning "economy head," while the "G" means "performance head." (The following information originated from Gary M. of the Toyota Mods Mailing List) The G head uses two widely spaced cams directly pushing the valves and driven by their own sprockets. This allows for very high valve speeds and excellent valve control for better performance. The larger angle between the valves also makes a chamber with more surface area, and with a domed piston, even more surface area. This allows for more compression while dissipating the heat better, so it won't detonate as easily. Also, the ports can be straighter so that they will flow better at high velocity thus making more top end power. Why does Toyota make an F head? The F head has close spaced cams with only one drive sprocket and a pair of gears to drive the other cam. The narrow angle between the valves makes for a more compact chamber that will hold the heat in and allow for a faster burn, and the port shapes improve low rpm velocity. This all makes for a more efficient engine with more torque at low speed and cleaner emissions while burning the lower amount of fuel. Basically, that is the reason for the two designs. The latest 7A-FE actually makes as much power as the MK1 4A-GE and more torque both at lower revs, but this is all due to the 200cc's more displacement. The better G head would definitely make even more but would consume more fuel and possibly lose some low end torque. Lastly, the "E" stands for "electronic fuel injection." The 7A-FE is available in the AE102 as well as in the ST version of late model (AT200) Celicas. The engine bay of these Celicas looks almost identical to the AE102's. Click here to see a 7A-FE in a Celica. Because of this engine "sharing," just about everything mentioned here will be applicable to the Celica 7A-FE (as well as any other 7A-FE).
There is more where that last bit came from at http://www.corollaperformance.com/Mods/ ... Index.html too
Hope that sort of helps.
Postby Mr Revhead » Wed Jul 07, 2004 2:40 pm
after spending a few minutes on the epc it seems there is two versions... one with dizzy the other multicoil
looks like the multi coil one (2 coils) is found in caldinas etc, corollas inc the nz ones have dizzy
some of that info above isnt 100% accurate..
i dont think 4age cranks are forged....
and some 'f' heads have 2 cam pulleys... but most (like 99%) have just the one then drive the other cam off the exhaust cam, but im sure matt knows that sort of thing :wink:
Users browsing this forum: Google [Bot] and 27 guests
