Redlines
Al
Contact:
Post by Al »
The EVILKP :twisted:
when the redline is lowered with the new motor it will be a different story tho 8)
event2
Post by event2 »
matt dunn wrote:
event2 wrote:my gtz turino
red line 7500 cut out 8000
but no point taking it past 7000 cos its dieing by then
speed cut? havent found one yet
i think its a factory computer but yea goes too fast.
Will hit speed cut just after the end of the speedo, 190ish.
lets jst say it dont cut then it keeps going :?
flygt4
Post by flygt4 »
yeah the ct26 made no extra boost after bout 5900 anyway...but wen traction was an issue it used to bounce on the limiter if u werent quick enuf to change it.think i did it once just to see what it went to :oops: witness in car wuld attest to 7800...was getting scared wen it started approaching 8
Jools... i found it strange that a jdm ecu didnt hav a speed cut when it was sposed to aye.
Jools
Contact:
Post by Jools »
flygt4 wrote:yeah the ct26 made no extra boost after bout 5900 anyway...but wen traction was an issue it used to bounce on the limiter if u werent quick enuf to change it.think i did it once just to see what it went to :oops: witness in car wuld attest to 7800...was getting scared wen it started approaching 8
Yeah I thought maybe mine was wired wrong, but used factory loom. I've only heard a few cases of this. Must be a different type of ECU?
Unless other people have had this?
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Rollux
Post by Rollux »
Al wrote:The EVILKP :twisted:
Hmmm, 100ish hp @ 8500rpm, or 220hp@6800. Hard decision really. Altho another hard charging 4K is in the pipes, but this time we'll get the next cam up and bolt on the twin dellortos! 8O
Watch for both at a drift track near you!!
BTW, my old 308 pulls to about 4800rpm safely, and breaks rockers at 6000!
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Inane
Contact:
Post by Inane »
my cressida went to about 9500rpm.... although that was when the transmission had already gone BANG and I was still getting it to move a little, with each rev increase, until about 5krpm then another bang hissing noise and the engine screamed a death scream of pain as it jumped to the end of the tach.
(I ended up driving home in reverse... for some strange reason that still worked great.)
Post Reply
