EGO sensor - when do you replace?
Postby Stealer Of Souls » Wed Jul 14, 2004 7:56 pm
I'm wondering how you would know when to replace the EGO sensor...
'86 AE85.5 Levin
Stealer Of Souls
Postby RedMist » Thu Jul 15, 2004 8:21 am
Engine check codes should give you a good idea.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Stealer Of Souls » Fri Jul 16, 2004 12:04 am
This leads to another (probably obviously answerable) question...
How do I check the check codes and what am I looking for?
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Mon Jan 08, 2007 8:53 am
Hey all...
Long time ago I was asking this question... And it's reared it's head again.
I've just finished installing a new combo gauge thingy which has and AFR reading on it. After tracking down the EGO sensor wire and connecting to it I fired up the gauge...
And no AFR reading... Or more exactly, it was off the bottom of the scale.
I have only run the car for about five minutes, as it was getting late and I had a long list of other stuff I had to finish. Is this my problem? Do i need to take the car for a good drive first?
Also, I've had the car on the dyno and the AFR was fine, so I'm assuming it's still okay since nothing has gone wrong.
Redmist mentioned checking the engine codes. How? What should i see? It may be a moot point since I don't know if my check light actually works...
'86 AE85.5 Levin
Stealer Of Souls
Postby Caveman » Mon Jan 08, 2007 9:55 am
Hey if you come to the ports meet ill bring you a cd with the complete 4age manual, its got detailed instructions on how to tell if its working properly.
I would just paste the pictures up but I dont how to extract them from acrobat reader :oops:
AW11 Track Toy
Formerly known as 1998
Caveman
Postby RedMist » Mon Jan 08, 2007 10:06 am
Stealer Of Souls wrote:Hey all...
There is a detailed article on club4ag re checking codes. Its a matter of jupering the diag port (E1 and TE1 from a very vague memory) and counting the blinks.
I gather you have plugged the AFR gauge up to the O2 sensor not the sensor on the cat? The Cat sensor is simply temp.
Edit: found the club4ag article. http://www.club4ag.com/faq%20and%20tech ... 0Codes.htm
RedMist
Postby Stealer Of Souls » Mon Jan 08, 2007 12:40 pm
Cheers guys.
Yeah, it's connected to the factory O2 sensor in factory cast manifold (is that the right term... I forget).
I'll have a squiz at that article and see if it works for me (sooo much dodgy wiring).
1998:
I've got a 4AGE manual. I didn't even think to check in there... It's all been such a tight time table... I'll have a read tonight.
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Tue Jan 09, 2007 8:14 am
So.
No output from EGO sensor = Bung sensor?
'86 AE85.5 Levin
Stealer Of Souls
Postby strx7 » Tue Jan 09, 2007 10:18 am
factory type narrow band oxygen sensors suck and you were wasting time and money even connecting a guage to it. if you want AFR's which are of any use what-so-ever you need a wideband 5 wire sensor and the appropriate guage/meter to go with it
Postby Stealer Of Souls » Tue Jan 09, 2007 12:35 pm
strx7 wrote:factory type narrow band oxygen sensors suck and you were wasting time and money even connecting a guage to it. if you want AFR's which are of any use what-so-ever you need a wideband 5 wire sensor and the appropriate guage/meter to go with it
The sensor is there. The gauge does it anyway... I just want the pretty lights to go up and down because they are there and they're supposed to.
'86 AE85.5 Levin
Stealer Of Souls
