20v Gearbox Question
Postby AXNGRL » Fri Jul 16, 2004 10:06 am
Before anyone jumps in, I have already done a search & no this info didn't come up. Maybe the last topic was too long ago?
But anyway :D
What is the code on the chassis tag for an LSD on a AE101 Facelift 20v?
AXNGRL
Postby AXNGRL » Fri Jul 16, 2004 1:34 pm
anyone?
AXNGRL
Postby Mr Revhead » Fri Jul 16, 2004 2:00 pm
um... iv yet to see a 20v with a factory fitted lsd.... not saying they definitely dont exsist but the epc doesnt show any options for an lsd in either the gearbox or axles.....
no ones been able to prove to me that they do exsist
Postby Silent Knight » Fri Jul 16, 2004 2:07 pm
i'm pretty sure some of the 111's came out wif factory LSD....i might be wrong on this but mine did???
Silent Knight
Postby MrOizo » Fri Jul 16, 2004 2:11 pm
Mr Revhead wrote:um... iv yet to see a 20v with a factory fitted lsd.... not saying they definitely dont exsist but the epc doesnt show any options for an lsd in either the gearbox or axles.....
update your EPC :P maybe nelson didnt get it :lol:
but yeah.. i heard it was almost stock for the AE111 20v's?
Could always search some of the US based toyota forums... they always seem to know alot about JDM options as they import engines and boxes to use in the US
MrOizo
Toyspeed Legend
Postby MrOizo » Fri Jul 16, 2004 2:14 pm
bling bling
told you the US guys know their shit..
hpe this helps...
http://www.mr2ownersclub.com/MR2FAQ_arc ... saxles.pdf
Gear ratios:
http://f3.aaacafe.ne.jp/~seltd/c-mission.htm
Copied below in case the page disappears
4speed:
C140 [ 3.166 ] [ 1.904 ] [ 1.310 ] [ 0.969 ] /R [ 3.250 ] EP82 (Soleil), EL41, EL51, EL52
5 speed:
C150 [ 3.166 ] [ 1.904 ] [ 1.310 ] [ 0.969 ] [ 0.725 ] /R [ 3.250 ] EP82 (S), EL43, EL44, EL53, EL54
C152 [ 3.166 ] [ 1.904 ] [ 1.310 ] [ 0.969 ] [ 0.815 ] /R [ 3.250 ] EL43 (FHE), EL44 (FHE), EP91 (NA)
C50 [ 3.545 ] [ 1.904 ] [ 1.310 ] [ 0.969 ] [ 0.815 ] /R [ 3.250 ] AE100, AE110, AE101 (4A-FE)
C52 [ 3.166 ] [ 1.904 ] [ 1.310 ] [ 0.969 ] [ 0.815 ] /R [ 3.250 ] EP82 (turbo), AE92 - AE101 previous term, AE111 (4A-FE)
C56 [ 3.166 ] [ 1.904 ] [ 1.392 ] [ 1.031 ] [ 0.815 ] /R [ 3.250 ] AE101 latter-term - AE111 previous term, EP91 (turbo)
6 speed:
C160 [ 3.214 ] [ 2.050 ] [ 1.481 ] [ 1.166 ] [ 0.916 ] [ 0.725 ] /R [ 3.250 ] AE101 (Serret/Mali last & touring wagon), first stage of AE111 latter term, AT210
C60 [ 3.214 ] [ 2.050 ] [ 1.481 ] [ 1.166 ] [ 0.916 ] [ 0.725 ] /R [ 3.250 ] AE111 latter term
MrOizo
Toyspeed Legend
Postby Mr Revhead » Fri Jul 16, 2004 2:20 pm
haha i was just doing a bit of research on the epc right now...
that info on the late ae101 is total bs im afraid.
they most definitly were not stock with lsd!
some versions of the AE111 had lsd, the bzr did standard, some ppl claim the bzv did but again no concrete evidence
the gear ratios are all good, but i dunno about some of the applications listed!
Postby Mr Revhead » Fri Jul 16, 2004 2:28 pm
sheesh... theres more bs in there...
first someone says the gtz used the 'c' series boxes, then hes corrected by some one saying they use the 'e' series (correct) and that person claims all gtzs had lsd standard, which is also not true...
Postby aesc » Fri Jul 16, 2004 3:10 pm
Ive got an E58-11C which has been said at http://www.twincam.org/forums as being an LSD. Not sure about C series boxes though.
You could always try the old fashioned way to find out :twisted:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Fri Jul 16, 2004 3:18 pm
i think the 'c' means lsd, but i havnt been able to confirm for sure... i know on the ae111 bzr it has a 'c' on the end of the code, and they do have lsd...
Postby Silent Knight » Fri Jul 16, 2004 3:24 pm
yea i'm pretty sure the C stands for LSD...
....and the BZG's all came out stock wif LSD
Silent Knight
Postby MrOizo » Fri Jul 16, 2004 3:24 pm
i thought the E** was the LSD series
MrOizo
Toyspeed Legend
Postby Mr Revhead » Fri Jul 16, 2004 3:25 pm
no not the bz-g the bz-r did 8)
Postby Silent Knight » Fri Jul 16, 2004 3:26 pm
the bzg must've cum out litmited edition LSD or sumfin then cuz i do know of a cuple of ppl with stock LSD in their bzg's
Silent Knight
Postby Mr Revhead » Fri Jul 16, 2004 3:27 pm
the 'e' is another series altogether, used in celica, currens mr2s and gtz levin/treunos and starlet turbos
there are lsd versions of the 'e' series boxes but most definitly the majority are not lsd
Postby Mr Revhead » Fri Jul 16, 2004 3:29 pm
its possible it was an option, its also possible they have been fitted after the vehicle was sold new in japan, they are after all 2nd hand when they get here and anything is possible in the mean time!
Postby AXNGRL » Fri Jul 16, 2004 4:29 pm
righty ho, just went & checked chassis tag, I have a C56 -15a.
What I want to know is can you buy an LSD & put it into the above gearbox or do you have to buy a complete new gearbox with it already in? if so, is anyone able to tell me which coded gearbox I need to buy?
AXNGRL
Postby aesc » Fri Jul 16, 2004 4:40 pm
If you want to turbo it, put a GTZ gearbox in it that already has LSD
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Fri Jul 16, 2004 4:54 pm
yes you can buy an LSD to fit, TRD do them amoung others.
however you will want an 'e' series box from a gtz levin/treuno for a turbo conversion
you can either get one with an lsd or fit an aftermarket one.
you will also need to get the axles with it.
youll kill a 'c' box damn qwik with a turbo 20v!!
Postby AceSniper » Fri Jul 16, 2004 5:10 pm
AXNGRL wrote:I have a C56 -15a
same as mine :D
AceSniper
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
