5K Carby Tuning ?
5K Carby Tuning ?
Postby z|gen » Mon Jul 19, 2004 6:20 pm
Well..iv finally finished putting the 5K carb onto my 4K manifold, and after about 15minutes of trying to get the thing started, it did, just not quite how i would have liked it to, it sounded like it was revving very high which im sure must have something to do with the tuning of it ?
Now, theres two screw like things with springs on the side of carb, one down near the where you mount it, and the other over by the accelerator butterfly, how do i tune the carb, is in, which way do i turn the screw like things so it is normal again, it never revved like it does with the old 4K Carb..
- David
AE91 SUPERCHARGED COROLLA
z|gen
Postby YeMs » Mon Jul 19, 2004 9:37 pm
mate, to be honest id take it to an old skool mechanic who lives and breaths carbs. it is really impossibly if u dont know much about carbs, its an endless hole of effort and at the end of the day for like $50 probly u could get sum old fella who raced a gt ford anglia in the gore grand prix to get it running like a sweetheart. the bottom screw by the mounting plate i think is the fast idle adjustment and the 1 up the top is the air/fuel mix adjustment. somethin like that.
YeMs
Postby z|gen » Mon Jul 19, 2004 9:49 pm
cheers dude, i would take it to someone, but a) i dont have the money, b) car isnt driveable, and i cant afford tow truck.
which way do i usually turn the screw to adjust them, is it clockwise or anti clockwise ?
- David
z|gen
Postby thaphatty » Mon Jul 19, 2004 10:07 pm
the one down by the throttle butterfly in the center is the mixture adjustment, righty-tighty leans it out if i remeber correctly. the one off to the side is the idle speed screw. turning it in makes the idle faster. if its running too rich it will idle fast too. if you carb doesnt have a manual choke then there should be another screw which will be cold idle speed.
can draw you a crappy diagram if you want.
thaphatty
Postby Lloyd » Mon Jul 19, 2004 10:09 pm
One will be idle adjustment and the other will change the mix (rich/lean). Screwing in means less air (idle) or fuel (mixture) past the screw which will lower idle or lean the mix depending on which screw you turn.
Someone correct that if its wrong
Postby thaphatty » Mon Jul 19, 2004 10:11 pm
sounds good to me 8)
thaphatty
Postby z|gen » Mon Jul 19, 2004 10:12 pm
so is there anyway i can know if i have the correct air/fuel mixture ratio, or is it gonna be a little touch and go ?
z|gen
Postby Lloyd » Mon Jul 19, 2004 10:14 pm
You'd need a gas analyser to do it right really which would involve taking it to a garage. Would be a reasonably quick job to get it right, but you'd have to pay someone to do it
Postby thaphatty » Mon Jul 19, 2004 10:18 pm
mines just tuned till it stopped backfiring lol :D
thaphatty
Postby z|gen » Mon Jul 19, 2004 10:19 pm
aight, might have to get it as best as i can, and then take it to tech or into work and fix it up, anyone know where i can buy a filter for these also, as i dont have the airbox or anything ?
z|gen
Postby Lloyd » Mon Jul 19, 2004 10:20 pm
Nothing on top of the carb at all? Heh, pantyhose do the trick if you dont wanna buy a filter :P Either that or go to a wreckers and find something that'll fit I guess
Postby z|gen » Mon Jul 19, 2004 10:23 pm
nope, nothing on top of it at all, i think il take the second option and go to a wrecker, i was thinking of making myself a cold air box and putting a vent on the bonnet, would it be worth it or not really ?
z|gen
