Al wrote:Wanna swap turbos and some cash The Prentender?
ThePretender wrote:GT4-SUM wound his boost up to 18psi and blew his up, so don't push it to hard... I heard it was an expensive lesson!
Anyone know what a new steel ct20b turbine sells for?
ThePretender wrote:I recently got my hands on another NZ GT4, it seems to come with the same specs as the rare WRC versions. But I was wondering whether the NZ versions come with a steel turbo or ceramic, does anyone know? it's the ST205 version.
Cheers.
Mr Revhead wrote:give me the full model and frame numbers, i can tell a few things from that.
but so can you... if the model number is st205r then its most likly a grp a.
the 'r' denotes a rhd drive vehicle destined for export countries
ThePretender wrote:It was first registered in July 94' and the chassis says it's number 5336. I know that the first 2500 are suppose to be WRC/GroupA cars, but maybe Toyota keep manufacturing them at the same spec for a while.
This is strange... maybe there are more Group A cars around then just 5
You are right that the R means right hand drive, but all that tells you is that it is right hand drive!
Users browsing this forum: No registered users and 79 guests
