Price on fitting left axel. . .??
Postby Banga69 » Fri Jul 30, 2004 5:10 pm
as the topic says whats the average mechanics charged? left axel connected to cv.
cheers clint
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby badidas » Fri Jul 30, 2004 6:48 pm
too much :lol:
find me a socket to fit the hub nut and a power bar and ill do it for $25
1989 mazda bongo aka [BNGBUS]
badidas
Postby AceSniper » Fri Jul 30, 2004 6:48 pm
shouldnt be to much I just got a new left axle seal put onto the box cost $45 labour so they pulled all that off an put it back i guess?
AceSniper
Postby 10k 20v » Fri Jul 30, 2004 8:18 pm
we do it here for $30 on a corolla, providing there's no prob's
10k 20v
Postby Banga69 » Tue Aug 03, 2004 12:23 pm
i sweet as.
do you have to take off the whole suspension?
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby badidas » Tue Aug 03, 2004 4:11 pm
nah theres a 32mm hub nut with a crown and a split pin through it undoo that buzz off the 2 17mm strut bolts get a soft mallet and tap the cv through outa the hub make sure ya put a bucket under the gear box incase it flows a rivver of gearbox oil and use axel stands
badidas
Postby 10k 20v » Tue Aug 03, 2004 7:09 pm
Or you could undo the ball joint via the two nuts and bolt at the bottom arm. That way gives the hub more movement and makes it easier to get the cv joint out,
10k 20v
Postby celica_tommo » Tue Aug 03, 2004 7:55 pm
thats how I'd do it... I think the strut nut/bolt is usually larger ~ 22mm
celica_tommo
Users browsing this forum: No registered users and 42 guests
