Fault Codes
Fault Codes
Postby as_cool_as_u » Fri Jul 30, 2004 8:07 pm
Where's a Good cheap place to get my fault codes checked for st185 gt4. from my experience auto electricians are dam expensive...
Im in Christchurch...any chance of gettin it done for like$20
as_cool_as_u
Postby Al » Fri Jul 30, 2004 8:16 pm
I'll do it for $20 8)
Al
Postby as_cool_as_u » Fri Jul 30, 2004 10:04 pm
k sweet.... u could drive it and il show ya what i mean bout pulling back after 5000 rpm... when can ya do it?
as_cool_as_u
Postby Al » Sat Jul 31, 2004 8:15 am
You can actually do it yourself as much as I'd like to take your $20 off you.
You can check it by jumpering the TE1 and E1 pins with a paperclip, in the diagnostic port in the engine compartment. Turn the key on (no start) and count the engine light blinks. The diagnostic port should be a little grey box with surprise surprise, diagnostic on it :)
Then the check engine light should flash something like this. FLASH.....FLASH FLASH = code 12.
If you want a hand I'll be home from work after around 6ish tonight.
Al
Postby B1NZ » Sat Jul 31, 2004 11:47 am
Does anyone have a list of all the fault codes?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Corona » Sun Aug 01, 2004 12:55 am
I think that the list here is pritty generic for most toyotas
http://www.carina-e.com/main/content.php?article.8
Neil
Just remember: The glass is neither half full nor half empty, it is merely the wrong size
Corona
