by jondee86 » Thu Aug 05, 2004 11:35 pm
When you have several different rotating masses linked together, as in an engine, you can get resonance occuring at various frequencies. This would typically give you some buzzing at certain engine speeds, for example, between 3000 and 3200 rpm. Above or below that speed the engine would run smoothly. There can be several resonant frequencies of different strengths.
A single out of balance rotating part would give you more and more vibration as the engine speed went up, and eventually the engine would poop itself.
Intake (or exhaust) resonance also typically occurs at a specific rpm range, related to the valve opening/closing frequency and the length of the intake runners. Above or below the resonant frequency, the noise/vibration disappears.
Does your vibration simply "go away" at certain revs ??
Did you change anything at about the time the vibration first became noticable... for example, a new exhaust ??
Are your new engine mounts made from harder material than stock ??
Alter the engine timing ??
jondee86
spec small port, twinscrew s/c and water/methanol injection
Watch this space >>> <<<
