marke wrote:mine idles high at the moment too. put your head out the window and sounds a bit like a rotor. have a look at the temp gauge, i thought mine was just broken but i now im under the impression the thermostat is broken so the ecu sends a rich petrol/air mix because it thinks the car is cold, so the car runs rich, uses more gas and i think can cause the idle to naff up a bit. but if your temp gauge reads normal then i would say you may be able to rule that idea out.
good luck
mark
levin_it_large wrote:i have a similar problem starts up @ 2K but after 5 or so minutes its goes back to normal idle, happens anytime of the day i could be back in the car in 20 minutes and it still revs @ 2K what could be my problem?
coolant and water needed in radiator? it a AE111 levin by the way
marke wrote:as i said above, my thermostat is broken. How hard is it to get to on a 20V silvertop? worth getting the mechanic to do, i understand the part is only about 20-30 $$ and a bit of labour so maybe a $100 all up doesnt seem that much but if its easy to do maybe id do it? anyone know or have done it before? cheers.
Mark
