how the hell do people get there ae85/6's so low?
Postby Dori_85 » Wed Aug 04, 2004 8:47 pm
im very interested in other people's suspension setups on there ae85/6's. mainly because ive just spent a shitload on suspension for my car and i have to get my koni's shortend quite alot(quite alot = 100mm) to keep the height that im satisfied with and have them captive. they are standard lengh koni adjustables so they have roughly 190mm of travel so if i take out 100mm is 90mm going to be enough shock travel?
just interested how much shorter the short stroke koni's are compared to standard lengh if anyone knows?
current: s14 silvia k's.
previous: ae85 levin 4agte, rt84 corona, kp61 starlet.
Dori_85
Postby rxtoy » Wed Aug 04, 2004 9:54 pm
i know in aussie (and i assume here) that people cut some of the length out of the strut body so the shorter stroke shocks are also starting their movement from a lower position. there's a few custom setup's around where the bit that the spring sits on has been cut off and threaded tube's welded on to make custom adjustable shocks, i'm not sure what the best springs are to use but i've heard of da6 integra one's being used in the front of a ke30. you'd probably want to work out what spring rate you want to use and look for something similar.
www.toymods.org.au forums have some good technical information about this sort of stuff but do a search first, the regulars are pretty quick to flame the lazy people (and the newbies that don't know :oops: )
for the rear just find springs that suit the height you want, measure the distance eye to eye for the shock and go see your friendly local shock dealer to find something the right length. alternatively garagedori have a bit of a list of stuff that will fit and the lengths and stuff
http://garagedori.com/tech/shocks.php
good luck,
hope it helps
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby gdsup » Wed Aug 04, 2004 11:23 pm
i run 420mm eye- pin rear shocks which keep it very captive and use very short stroke fronts, which are just captive but prob need the strut body mod done as well
gdsup
Postby Drifter4ag » Thu Aug 05, 2004 1:12 pm
i run stock springs and choppy chop till nice height or on bumps
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby THA SHZ » Thu Aug 05, 2004 1:21 pm
Makita lowering kit or ags (angle-grinder suspension) :lol:
THA SHZ
Postby AE85.6 » Thu Aug 05, 2004 3:58 pm
nah man ive been in your posistion ay this is the age old question as far as i am concerned,
king spring and almost all other spring brands only do the 30mm (ish) drop no one seems to do the super low option,
and i didnt really wanna do only a 30mm drop cause the fact that these are one car that is just quite high in stock form,
my mates trueno is really low but he bougth it that way compared to my levin with stock units (front shox leaking oil too) the rear was like alomost 70mm lower and front about 50mm,
i didnt wanna go that low but more than 30mm if possible so the top of the sidewall of the tire is inline with the guard,
i ended up buying a set of trd springs through Mr Revhead which were a good price and also good cause you can pick your own spring rates too, these are supposed to be 30-35mm drop which seemed to be the best i could find without compressing ones which is what my mates trueno has, also got some trd shortened shox to try keep everything captive and road legal and hopefully drag it a little lower, rears were about 70mm shorter than stock and the fronts were 96mm i think, still gettin the front sorted and installed at the mo but the rears are in and with my shitty 13s on the back (2 rear mags still gettin polished) the guard sits inline with the top of the sidewall so hopefully thew front will be equally as low and with my nice wheels on there should be no ugly big gap between tires and guards
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby Dori_85 » Thu Aug 05, 2004 7:24 pm
on the front ive angle grinded the old spring platform off and welded a smaller platform on for my coil overs to sit on, it all works pretty well but im just wondering if i cut as much as 100-120mm out of the shock shaft is that a bit much? if the entire lengh of the shock shaft is only 180-190mm. and on the rear ive welded a new platform on the diff and were the bump stop was for a smaller custom spring to sit on. its at the height i want it im just wanting to know if cutting that much out of the shock is going to stuff up the travel?
and also ive seen other peoples cars that are lower than mine but how the $&#$% have they done it?
Dori_85
Postby gdsup » Fri Aug 06, 2004 12:16 am
sounds like you need to do the strut body mod, and use ae92 style shock, think there is a tech article on www.club4ag.com
gdsup
Postby Voodoo » Sat Aug 07, 2004 4:13 pm
well, im quite happy with my height, the rears a trd race springs, with koni ajustables as u know, but i had to get them short'n to hold trds captive, the front is king /koni ajustable coilover, can go abit lower than the rear, but its set around the same height, but none of this was a DIY joby, im no mech so i went for the pricy option of getting things done by workshops
Voodoo
Postby AE85.6 » Tue Aug 10, 2004 8:16 pm
ye me too man i didnt have all the tools needed to do the job myself and the place i was staying at the time was only a carport and in the pissing rain i couldnt be assed installing it myself, took all the parts to a freindly garage and only a couple hours and all done, looks good now with 15" celica wheels the front sits about one finger space above the guard and untill i can afford another to tires i cant tell you how the rear sits, but with fugly 13" wheels on the rear the poke a bit under the guard, im pleased with the look alot lower than before but not ridiculas, but have to get used to a low car again as i backed out the drive and farked my exhaust :evil:
sounds like i did similar thou i just shopped around for the parts and just got them installed, if you shop around and get a deal you can sometimes afford gettin it fitted for you,
i just installed a set of trd springs 6kg rears and 8kg fronts with pre shortened trd adjustable shox all round,
got them all thru Warrick at Toyota (AKA Mr Revhead) good guy did me a good deal was cheaper than other people quoted and was good cause he was interested in helping not just getting a sale
AE85.6
Postby pplmvr » Tue Aug 10, 2004 8:28 pm
I don't know, I guess just get some Cusco suspension etc, high low kit etc
Big Is Good & Its Great to Play Together
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby spencer » Wed Aug 11, 2004 3:14 pm
Bro why reply with that weak post when other people have already explained their setups. For me at the moment my setups abit rugged kings in the back with a half coil chopped off ke36 shocks (soft) and almost finished some hieght adjustable coilovers for the fronts. Threaded sleves from stocks shortened strut and ae92 shocks(munroes soft but ok for now)
ms63 crown
spencer
Postby boxxy » Wed Aug 11, 2004 11:31 pm
this is what ive been told are in mine (were in there when i brought it) jamex font springs and gab shocks, and the rear has been cut 2 6 coils (says so on the cert plate :twisted: ) with "x brand" shocks
it handles pretty damn good for the tires its got, a tiny bit sketchy on mid cnr bumps but its livable, and the rear is damn solid, and likes to hang out with out using the right foot.
as to the height, the front is mint and the rear is good (a lil uneven side to side) its written as 300mm wheel center to gaurd all around on the cert plate.
the pic on my profile doesnt give it justice as to how low it is
my 2c any how
Tim
1997 Corolla GT.... AGGGHHHHH too many valves
101.5KW atw :D
"Open your throat, we know you can!"
boxxy
Postby AE85.6 » Thu Aug 12, 2004 2:38 pm
ye sounds like quite a few different options everyone has done to get good results and the best way is to ask what others have done to get ideas, cause i have seen a few 85s with just a set of king springs and normal shox and didnt lower it much at all and ruined the look of the car as it wasnt near the 30mm odd drop it was supposed to be
AE85.6
Postby AE85.6 » Thu Aug 12, 2004 2:41 pm
AE85.6
Postby spencer » Thu Aug 12, 2004 2:47 pm
Plus the kings on the car I bought off you you ae85.6 went even captive which it pretty gay for bugger all drop. So make sure you sort some short shocks out when you get it lowered and an adjustable panhard rod for the back if you need it
ms63 crown
spencer
Postby JT » Thu Aug 12, 2004 3:48 pm
ke70wagon20v wrote:Plus the kings on the car I bought off you you ae85.6 went even captive which it pretty ghey for bugger all drop
This is my current problem. I have lowered springs with standard shocks and when it's jacked the springs aren't captive. The car isn't even low and I want to lower it 'more'. New springs are obviously a necessity but what am I to do about shocks?
AE85.6; how have you found the TRD springs? They obviously give a good drop if you had to shorten the TRD shock? Or are the TRD shocks standard length and travel?
gdsup; If I use the ae92 shock and space it, how low a spring can you use before the strut mod becomes necessary?
JT
Postby jimi » Thu Aug 12, 2004 4:48 pm
has anyone used hilux kyb's in the rear? saw the suggestion on the garage dori site. i have some cut jamex springs im replacing the stock ones with, and im pretty sure they wont be captive with stock shocks. Would i need an adjustable panhard rod?
jimi
Postby Mr Revhead » Thu Aug 12, 2004 4:59 pm
the TRD race shocks come in several different lengths, when ae85.6 said 'preshortend' he meant they are made shorter than the stock items, they are not modified after TRD make them.
hope that clarifys things a bit!
Postby gdsup » Thu Aug 12, 2004 7:47 pm
JT: i use a trd 8kg race spring, with ae92 shock and spacer, just captive, with suposed 50mm drop
jimi: i use 420mm shock sim to hilux, and keeps very captive with not much droop
gdsup
