badidas wrote:hey bro your gearbox is most likely a w55 engine will bolt straight up to existing mounts give yems an email as hes done a ke30 3tgte and has various spare bits
engine and loom will set ya back $1200 or there abouts
140kw 160hp
i sold my 3t for $800 but that was mates rates ay and i needed the $$
your better off with 3tgte in the long run because its already set up for it
check out my site for sum info www.freewebs.com/corolla_information/
take a chill pill i was offering my opinion on the subject as i have done a 3tgte ke70 recently isnt that the whole point in asking a question to get advice and different opinions
peace
Information is only worthwhile if it is ACCURATE!!!!
dont know much about this engine.
it already has a 3t in it so it should all bolt up to the mounts that are in it?
it has a 5speed in it, but as the conversion was done before i got it i dont know what the box is (any guess')
obviously i need to do the brakes at the same time...
what should i do there?
how much would the engine cost roughly.
if it would all cost a fair bit, i might just put a 12a in it (sooner or later)
any body know how much it would cost to do the whole conversion, assuming that i did none of the work myself.
