do i need air flow meter???
Postby rollas22 » Fri Aug 13, 2004 1:13 pm
AE101 Toyota Levin 4AGE 20v silvertop (TURBO)
Just about to place all my piping into the car for the intercooler and turbo, and was wondering can i remove the AirFlow Meter??
Will it work with out it?
KE-Corolla's for life!!!
rollas22
Postby the fallen303 » Fri Aug 13, 2004 1:18 pm
unless your running a map aftermarket ecu, then yes, you do need it, as thats what the ecu uses to determine the air coming into the engine. if your turboing a stock 20v, then i'm guessing your running a aftermarket ecu anyway.
true house of JZ
Stay true to the origin
the fallen303
Postby rollas22 » Fri Aug 13, 2004 1:31 pm
woopz shud have sed that in my 1st post. Its not a standard 20v, its fully been rebuilt with forged components. Also will be runing a LINK V4 ecu... so what your saying if i run an aftermarket ECU then i dont need to have my airflow meter there?
rollas22
Postby Rollux » Fri Aug 13, 2004 1:34 pm
If your running a link you should be able to throw away the AFM and replace it with a MAP sensor
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Rollux
Postby rollas22 » Fri Aug 13, 2004 1:41 pm
where do i get a map sensor from? what does it do help me on this... what it look like?
rollas22
Postby mike simmonds » Fri Aug 13, 2004 1:56 pm
it looks like a little black box with a vac hose goin to it from ur inlet manifold, also wires that go to comp
mike simmonds
Postby spencer » Fri Aug 13, 2004 2:09 pm
cullem the dude who wired up your link should have sorted this for you. He should have thrown your AFM in the bin and the map should be all wired up
ms63 crown
spencer
Postby rollas22 » Fri Aug 13, 2004 3:56 pm
problem solved, rung Informotive in Rotorua and they where a great help. i will be taking the car over there in the next 2weeks to get a full wire and tune done on the car.
The link that i will be using "LINK V4" has a built in MAP Sensor, so i can just bin the AFM and start fresh with the link option.
rollas22
