MA61 rev counter ?
MA61 rev counter ?
Postby GT4A_widebody » Fri Aug 13, 2004 7:51 pm
yea ive just had my MA61 on the dyno b4 i mod it and the rev counter is out and restricted me to only getting 86.8kw at the wheels at 5000rpm.
so they werent able to rev it to 6500rpm . so if anybody has any info or help they can give it wud b greatly appreciated thanks
Damb i dnt c y its illegal to use afgas in my celica ????
GT4A_widebody
Postby Adydas » Fri Aug 13, 2004 8:12 pm
traction control?
Adydas
Postby Silent Knight » Fri Aug 13, 2004 8:18 pm
i didn't think traction controll will keep your revs down? and do you actually lose that much tracktion on a dyno?
mbe a short sumwhere? fuel cut...boost cut?
Silent Knight
Postby Adydas » Fri Aug 13, 2004 8:23 pm
traction control held gadgets supra back on the dyno some how.. i forget..
well if my memory serves right anyway..
he was held to low boost or low revers or sumthing..
is the car FINE on road but not on dyno? if so it sounds simlar.. something to do wioth all wwheels have to be turning.. and on dyno there not.. just rear so it goes Hang on im wheel spinning must bang in traction control stop this out of control madness
Adydas
Postby Adydas » Fri Aug 13, 2004 8:24 pm
and ISNT fuel cut.. just another word for Boost cut??
Adydas
Postby Rob_GTZ » Fri Aug 13, 2004 8:42 pm
Traction Control?? On a MA61?? :lol: Remembering that the MA61 was produced in the early 80's.
Rob_GTZ
Postby Adydas » Fri Aug 13, 2004 9:21 pm
yea i realise that.. i have no idea how far first tc dates back to..
so if its not that.. what is it?
Adydas
Re: MA61 rev counter ?
Postby Toymad » Sat Aug 14, 2004 8:39 am
GT4A_widebody wrote:and the rev counter is out and restricted me to only getting 86.8kw at the wheels at 5000rpm.
Why do you think the rev counter limited the engine revs? The rev counter is purely a measuring device in the earlier Supras (like yours). The ecu is the thing that will limit the rpms.
Did you or the dyno operator disconnect the rev counter?
When it was revving, would it only go to 5k rpms? What about if it was in neutral? It could well be you have an ignition problem that shows up more in the upper rev range.
Toymad
Postby GT4A_widebody » Sat Aug 14, 2004 4:30 pm
cause the monster tcho was hooked into the standard tacho feed it read the same as the standard tacho. but the system they used to dyno it with was hooked on to one of the plug leads and read 5000rpm while the monster tacho read 11000rpm. he said the factory tacho was out and was causing it to cut out at the true 5000rpm when it should cut out at 6500rpm.i have been told it could be the ignitor or something if any body has had this problem can they help. please
GT4A_widebody
Postby deaf_rattle » Sun Aug 15, 2004 2:34 pm
Rob_GTZ wrote:Traction Control?? On a MA61?? :lol: Remembering that the MA61 was produced in the early 80's.
ma61s had alot of features for their time.
but no, no traction control, but alot more value for your money than buying an 86 :lol:
Postby Toymad » Sun Aug 15, 2004 6:58 pm
GT4A_widebody wrote:cause the monster tcho was hooked into the standard tacho feed it read the same as the standard tacho. but the system they used to dyno it with was hooked on to one of the plug leads and read 5000rpm while the monster tacho read 11000rpm.
I'd still have tried disconnecting the monster tach and then the entire dashboard if the standard dash still read wrong.
GT4A_widebody wrote:i have been told it could be the ignitor or something if any body has had this problem can they help. please
There is a guy in Wainui who was wrecking a few MA61s a little while ago and he may have spares (pm me for his number). Does it just cut out or does it run rough???
Toymad
