launch control, hows it work
Postby RedMist » Sat Aug 14, 2004 7:23 pm
Actually you'll be better off if YOU can control the throttle in two ways.
1. Introducing a missfire without reducing fuel causes washing of the cylinder walls. This increases wear and dilutes your oil.
2. WOT there is no restriction in flow, velocity slows and fuel falls out of suspension so you get less HP. If you can modulate the throttle then you have more HP because the throttle plate causes turbulance and a restriction in flow, increasing velocity. Try it next time your on a dyno, they test HP at WOT, but you can increase low and mid range HP by just closing the throttle somewhat!!!
Nitro mixes are a little different as the fuel air mix doesn't need to be as accurate.
The best solution for launching is throttle by wire, where the computer controls the throttle. Looked at doing something like this, but I'll have to wait for the Ultra Mega Squirt in order to have the clock cycles to drive the bloody thing!!!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Fred » Sat Aug 14, 2004 7:30 pm
is the ultra mega squirt better than just a power link? or is it just cheaper? u gota make them up urslf aswell dont u? is it fairly safe to make it urself?
i need something to control an extra injector soon to b plumbed into my ic piping.
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby kingcorolla » Sat Aug 14, 2004 8:14 pm
i herd sumwere, u can run a pressure switch, off ure volage regulator (5v i think) and just hook up an extra fuel line. maybe a return aswell. Make sure the switch is a low tolerance switch so it activated when turbo starts spooling.
RANGIMODS.COM!!! thats were i herd it.
1983 Carina AA63 4age
kingcorolla
Postby kingcorolla » Sat Aug 14, 2004 8:19 pm
kingcorolla
Postby Fred » Sat Aug 14, 2004 8:24 pm
wud that give an accurate rate of fuel? or wud it b constant same rate wen turbo comes on cause powerlink varies dosnt it? like wen u boost hard it squirte more petrol? anyhoo wud it work for sc? cause aint got a turbo
Fred
Postby Lloyd » Sun Aug 15, 2004 10:10 am
Ummm... thats the point of rising rate fuel pressure regulators isn't it? More boost = more pressure at the rail = more fuel into the engine on boost.
Postby RedMist » Sun Aug 15, 2004 12:13 pm
If your after some form of easy accurate fuel control then the UMS isn't for you. It'll work out at about $400 US including the stimulator.(when it's finally released) Then you may have to write your own code, tuning isn't the easiest and it won't be anywhere near as stable as the Link products. I run two Links in my two race cars at present. Very good basic computers, I've had absolutely no problems with them. (had problems with the early link ignitors, but thats a different story).
By installing an injector that comes on at a certain amount of boost you'll end up with lean and rich spots. Cheap solution, but by no means a good solution. If you can get a cheap link, go that way, you won't regret it in the long run.
RedMist
Postby Bazda » Sun Aug 15, 2004 1:25 pm
Powerlink additional injector controler, its what I run and have for some time now and mixtures stay constant through out the rev range. I'm very happy with this product.
Users browsing this forum: No registered users and 32 guests
