pplmvr wrote:$200 hmm thats a bit steep etc..
The process involved including
1.Install the Knock sensor
2.Swipe your EFTPOS card for $200
3.Print you a receipts
4.Say thank you and wish you never come back for any warranty issues..
JiNX wrote:pplmvr wrote:$200 hmm thats a bit steep etc..
Not all that easy really, have you ever looked to see where the thing is located??? Sure, $200 is on the steep side, but at least it gives you peace of mind that if they crack the block from over-tightening it(Knock sensor has tapered thread), it's up to them to fix it.
I'd assume that price also includes the new intake manifold gasket.
pplmvr wrote:I don't know speak to someone who really knows/cares like the owner of this car and if you know please tell us the processed involved ?! :roll:
Bazda wrote:it takes me 15 minutes to change my knock sensor,
15 minutes $200..........wow!!
i'l do it for $150!!!
all u need is a 27mm socket thats deep reach.
then unclip th plug and pull it out, u might need someone to pull onthe wire while u push th elittle clip thing that holds it on.
then get the socket with an extension and go for it.
make sure u do it when eng is cold!! or u burn your self real bad
Banga69 wrote:is it really that simple? so how come king toyota quoted be between $250-$350 for 3-4 hour jobby??
