WALT3R wrote:the bigends have gone in such a way that a piston is smaking the cylinder head.
and my friend? forged pistons are in practically every car these days, i think these engines are forged standard. if ur upgrading pistons? TITANIUM is the one haha.
Al wrote:Did you contact Warwick, Mr Revhead like advised?
If he cant find you one, you're sh*t out of luck.
Al wrote:3sgtes dont have forged pistons standard, they are cast.
WALT3R wrote:Iv talked to a chap about that. It will fit, but there will be a hundred million little things that you have to change, waaaay too much f**king around. sound advice for anyone upgrading an engine, instead of putting a newer engine in, just buy the newer car.
All_Fours wrote:ahahaha
How do the bigends go in such a way that the piston is smacking the cylinder head? Did you take the sump off and loosen the bearing caps or something? or has the whole conrod or crank distorted so much that the stroke has increased a few mm?
WALT3R wrote:Hey guys. I have a 1990 celica gt4 group a. Its sh*t itself big time. Iv been advised to look for anotha engine (its the big ends, will work out cheaper in the long run to get a new engine). Does anybody know of any up for grabs????? Turbo, intercooled, E-ST185H-BLI1NZ, 3SGTE. I am based in rotorua, but im sure freight will not be a problem so yeh, location is not an issue. I will need some sort of certification that shes a good'un, as you will understand. Thanks a lot. If u can find me sumthing that ends up worthwhile a box ov beers is in it for you.
