hmmm, found a vacuum hose...
Postby AXNGRL » Mon Aug 16, 2004 10:35 pm
Ok, 10 points for whoever can tell me where this hose is supposed to connect to...
AXNGRL
Postby AXNGRL » Tue Aug 17, 2004 10:10 am
Come on, someone must know!
Further info since pics aren't very clear:
Its on the firewall side, top right of rocker cover, there are 2 hoses that sit on top of each other, its the bottom of the 2... 20v silvertop levin...
AXNGRL
Postby AceSniper » Tue Aug 17, 2004 10:45 am
thats one hell bad pic :P
but semi looks like the hose my vacume guage is on...
Ill have a look inawhile an re-post if sum1 dosnt beat me
AceSniper
Postby AceSniper » Tue Aug 17, 2004 10:59 am
okies...
its the middle size one outa the 3 aye?
It goes on to that group of steel tubes that have heaps of vacume hoses connected... then from there goes back to rubber and it grouped with a 2nd tube the same size that looks like its hooked to the powersteering.. well down there...
But if u just have a small bit of rubber pipe... ya just needa take a look at that group of steel tubes that are bolted on with all the vacume hoses connected just below and back abit from the lift hook, there bolted to the plenum.
was this ur prob at the drags? *finks i shoulda come over an asked*
AceSniper
Postby AXNGRL » Tue Aug 17, 2004 11:04 am
sounds like you could be right, squid did mention that the hose joins on at the top (in bad picture) & then goes down into thin metal pipes, its joined on to the pipes, just need to know where it finishes its circuit, its quite a long hose & we found it tucked down the back of the engine by the firewall...
AXNGRL
Postby AXNGRL » Tue Aug 17, 2004 11:12 am
Yes, it was my problem at the drags :(
This is causing the car to idle rough as guts & die whenever you stop... ie, traffic on way to work was a biarch. We currently have the hose blocked off with tape & car seems to run fine...
AXNGRL
Postby GTCRSHR » Tue Aug 17, 2004 1:58 pm
on my old ae82 corolla it did the same thing as that sounds really bad
but still goes and eventually cuts out
idals around the 500 mark right ?
it went into the TVIS unit on the old 4age
not much help but u never know ?
GTCRSHR
Postby AceSniper » Tue Aug 17, 2004 2:33 pm
itll make ya car run shit... coz its letting air in = run lean (i think)
anyway from what I could see with out pulling stuff apart it ran from that metal pipe with another hose from that area down to that bump in the firewall (think its sum kinda cover) by the steering rack... so im guessing its todo with the powersteering? not much else down there it can hook to
AceSniper
Postby AXNGRL » Tue Aug 17, 2004 3:46 pm
my silvertop doesn't have TVIS... but cheers anyway :D
AXNGRL
Postby AXNGRL » Tue Aug 17, 2004 3:55 pm
failing that, anyone got a 94 silvertop in the east auckland area that we could come & have a look at?
AXNGRL
Postby AXNGRL » Tue Aug 17, 2004 10:39 pm
any takers?
*bats eyelashes*
AXNGRL
Postby 92GTApex » Wed Aug 18, 2004 1:25 am
Ill go and have a look at mine tomorrow when theres some light...
Its not a facelift 20valve but that wont make any difference(well shouldnt do anyway :lol: )
Logan[/quote]
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby GTCRSHR » Wed Aug 18, 2004 9:46 am
i have a 94 fxgt with a silver top ... pm me if you want to come have a peak and am out east
GTCRSHR
Postby AXNGRL » Wed Aug 18, 2004 9:54 am
you've got mail :)
AXNGRL
Postby Nathan Young » Wed Aug 18, 2004 1:27 pm
if you havent tryed this already and the hose is not to long it should naturally go some were close to were it came off only catch is it mite of turned on other end. had a simler prob got a tourch and carfully looked where hose went as i turned it dident take me to long to find.
hope this is some help probably not but good luck anyway.
Nathan Young
Postby AXNGRL » Wed Aug 18, 2004 1:40 pm
its quite a long hose & it was tucked down & through other hoses on the firewall side, with nothing obvious in the general vicinity to attach it to... will see if looking at another car gives us more clues... :D
AXNGRL
Postby Nathan Young » Wed Aug 18, 2004 1:49 pm
cool just thinking if ever happens again at drags try doing the damsel in depress thing you will have so many guys trying to help will be fixed in know time :wink:
Nathan Young
Postby AXNGRL » Wed Aug 18, 2004 2:31 pm
:lol: :lol: :lol:
AXNGRL
Postby AceSniper » Wed Aug 18, 2004 6:23 pm
as iv said both hoses (the one it runs down beise) go down to that bump at the bottom of the firewall on the drivers side... (powersteering?) but yea may have to go under the car to see it clearly...
AceSniper
