water pump for a ae101 how much to fix
Postby LVN2NV » Tue Aug 17, 2004 6:37 pm
my car is leaking radiator fluid and its not comin from the radiator or the over flow bottle so i assume it is the water pump any one no wat im lookin at cost wise to get this fixed?
Now the Proud Owner of a Altezza Rs200 :D
Future ride = Altezza
Previous rides= ae101 levin, ftzs corrola
LVN2NV
Postby Dr-X » Tue Aug 17, 2004 6:50 pm
on my sigma cost $450 incl labour and pump. If i knew how easy a job it was, i would have done it myself.
Dr-X
Postby Dodgy Guy » Tue Aug 17, 2004 7:11 pm
im getting my 1992 fxgt's water pump replaced as we speak.
costing me 350 all up for pump, cambelt and labour.
Dodgy Guy
Postby EVLGTZ » Tue Aug 17, 2004 9:08 pm
it's a pretty simple job.
the pump itselft is only like $80-100 at appco from memory
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby strap-on » Tue Aug 17, 2004 9:22 pm
ive done it on a lada and it was piss easy. just have to take all the belts off ( make sure u put marks on the cam gears to keep track of the timing,) and then yeah just unbolt and replace, top up ater etc replace belts, make sure they are correct tension and yeah
strap-on
Postby Mr Revhead » Wed Aug 18, 2004 11:33 am
new genuine pumnp for $96 here!
pm me if ya want one. good idea to do cambelt and drive belts at the same time as they all gotta come off to do it!
Postby Sanxta » Wed Aug 18, 2004 11:36 am
Don't assume it's your pump - it could be something else like the frost clips/plugs which leak water but not from the radiator or bottle.
Sanxta
Postby Ae92typeX » Wed Aug 18, 2004 2:01 pm
Yeh, get a torch at it and look around, like above could be frost plugs, possibly a joint somewhere or even a small pinhole in a hose somewhere!?
youre getting a puddle under the car?
Ae92typeX
Postby LVN2NV » Wed Aug 18, 2004 3:23 pm
Ae92typeX Posted: Wed Aug 18, 2004 1:01 pm Post subject:
we got it up on my bfs hoist at his work and we couldnt see where it was comin from, get a puddle under car sometimes big sometimes only a little its weird
cheers everyone for ur imput :D
LVN2NV
Postby rollas22 » Wed Aug 18, 2004 3:38 pm
That soundz exactly what my ae101 levin was doing, it was the waterpump. Easy job to do. make sure when its replaced, that the O-ring is replaced and check the seal. You dont want to put it all back together then have to remove it all.
KE-Corolla's for life!!!
rollas22
Postby Ae92typeX » Wed Aug 18, 2004 3:48 pm
Also, its not your aircon is it?. If the radiator is loosing water than obviously not, but occasionally people forget aircon drips when being used. Just a final thought before you pull it to bits.
Ae92typeX
Postby B_giB » Wed Aug 18, 2004 6:58 pm
tis defenatly green antifreeze Ae92typex,
but yea, dosent use water from radiator, just have to top up the overflow bottle every now and then
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Users browsing this forum: Google [Bot] and 38 guests
