wheres my coil/distributor? (pics)
Postby minijrocks » Wed Aug 18, 2004 4:50 pm
hi, im trying to find the negative on my coil thing but dont know where the coil is or if i will have a negative on it. Ive got some pics of my engine bay (1991 trueno). would someone be able to show me where it is on these pics.... Pm me, post up, or email me minijrocks@hotmail.com or msn, with an arrow or something.... thanks
http://community.webshots.com/user/minijrocks-date
minijrocks
Postby minijrocks » Wed Aug 18, 2004 4:52 pm
minijrocks
Postby z|gen » Wed Aug 18, 2004 4:58 pm
you will have an internal ignition coil on your distributor, you are probably, better off finding a wiring diagram - i have one somewhere on my computer and then finding a diagram for the pinouts on the ECU and wiring it from there, or you can follow the diagram and wire it off the distributor, but im not sure which part, as im only used to working with external ignition coils..but either way, you will need a wiring diagram
AE91 SUPERCHARGED COROLLA
z|gen
Postby solberg Fan » Wed Aug 18, 2004 5:01 pm
Follow the high tention lead (the only big black wire one not going into the engine as the other four are doing) from your distributer. It will be conected to the coil. The negaive wire, im not sure on an electrical set up, But it wil be a wire coming from the distibuter to the coil. But dont take my word on that last part. :lol:
Edit: Why would there be a high tention lead if the coils is an internal one?? :? - still recken its an external one. What do other people recken??
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby rollas22 » Wed Aug 18, 2004 5:22 pm
this is the easiest thing to wire up ever! On ur distributer cap, follow the main wire (the1 that dnt go to a sparkplug) and that will take it to the coil. then find the negaitve on that. shud be a black box type thing.
KE-Corolla's for life!!!
rollas22
Postby z|gen » Wed Aug 18, 2004 5:38 pm
ok..
is this for an ae92 or ae101 or what ?
if its for one of those, im 90% sure i have a wiring diagram which i can put up for you to print off, then go to your engine bay, find your distributor, get out your lil test light..and probe the wire to death..:D..
if you still get stuck, i suggest taking it to an auto sparky and paying them to do it.
z|gen
Postby minijrocks » Wed Aug 18, 2004 5:45 pm
its the 1992 shape 20 valve 1.6 super slut one.also, if i get all the wires into the engine bay, how much will it cost to get the 3 wires wired up....? like $20 (hehe im cheep) - where is a good auto electicition on the shore i can take it to? pref cheap!!!!
minijrocks
Postby thaphatty » Wed Aug 18, 2004 6:16 pm
hahahaha super slut... crack up :lol:
thaphatty
Postby matt dunn » Thu Aug 19, 2004 12:06 am
minijrocks wrote:its the 1992 shape 20 valve 1.6 super slut one.also, if i get all the wires into the engine bay, how much will it cost to get the 3 wires wired up....? like $20 (hehe im cheep) - where is a good auto electicition on the shore i can take it to? pref cheap!!!!
Since I presume you are not super mechanically minded ( no offence intended) the easiest place to find the required tacho feed is in the black plug under the bonnet labeled DIAG or Diagnosis.
Open it up and the pins are labeled. The one you want is larger than the rest and is in the centre labelled IG-.
Matt
Postby NA Drifter » Thu Aug 19, 2004 2:27 pm
ur coil is the photo 5. CIMG0231.. the one that got a spark plug wire plug and a 2 wires plug.
one of the plug (2 wires) terminal is negative.. i forgot which one...
Keith
NA Drifter
Postby minijrocks » Thu Aug 19, 2004 10:58 pm
thank you for that. will check tomorrow when i get my hands on a multi meter....
minijrocks
Postby minijrocks » Wed Aug 25, 2004 5:42 pm
ok ive found it and installed it a few days ago. Maybe you should put this under tech fAQ because i have seen a few recent posts on how to do this. I can also get some more pics if thats more helpful for you guys where and how to get the wires into the engine bay and where they go ect... :D
minijrocks
