mike simmonds wrote:yea put it in the top of the sump as oil will gravity feed back. if u return it below the oil line in the sump the oil cannot return properly and most probalbly push out seals of turbo.
MrOizo wrote:also make sure you have good ventilation - such as an oil breather.. want to geep the pressure in the sump to a minimum to stop the oil blowing out the seals of the turbo
badidas wrote:also i noticed on www.rangimods.co.nz they put the oil return to the dipstick lmfao
