Muzzie wrote:Question I now have to ask is....
2.5l 1JZGE or GTE, Or Lexus V8 - will it fit?, and easily?. I'll have to get a new geabox too, and I want a manual.
At least with something with some grunt I'll be able to pull my racecar around easily. Poor van struggles a bit at the moment.
And it doesn't sound too bad - they have a common fault where they leak around the downpipe (which mine does) and around 3000rpm it sounds beautiful in my humble opinion.
MetalupYoAss wrote:nah the Y series engines are designed for commercial use, i doubt they would have ever made a turbo model, plus its not really worth turboing your 3Y, itll take so much work and not give that much more power
jjd wrote:MetalupYoAss wrote:nah the Y series engines are designed for commercial use, i doubt they would have ever made a turbo model, plus its not really worth turboing your 3Y, itll take so much work and not give that much more power
In fact there is a turbo 3y,EFI as well,comes in a 88-89 townace super custom,with the sliding curtins of course.I know had to build a new front pipe for the thing as it was stuffed.
