cams and lash caps
cams and lash caps
Postby Fred » Tue Aug 24, 2004 9:33 pm
Hey all, at first i was under the impression that a 272 grind wud b best for a 4agze with a sc14 conversion as the sc14 would help with the mid range and the 272's up top, but since then am wondering if the 264 grind is better? wud having a 272 mean lumpy idle and crap gains without an aftermarket ecu?
anyway the main point of this post was to get suggestions on what could be expected to be paid for an individual lash cap
thanks
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby ChaosAD » Tue Aug 24, 2004 9:41 pm
about $10 - $15 +gst
ChaosAD
Postby Fred » Tue Aug 24, 2004 9:45 pm
Fred
Postby boyracer69 » Wed Aug 25, 2004 3:19 am
Most places include it in the price for the cam grind..well i no kelford do :)
boyracer69
Postby ChaosAD » Wed Aug 25, 2004 8:13 am
only if you ask for them. the guy who bought the cams might have wanted to build up the valve stems instead
ChaosAD
GRIND
Postby CAMB01 » Wed Aug 25, 2004 9:54 pm
A 264 degree grind is the maximum duration the ECU can handle, any higher and you'll have a bad idle, and leaning problems.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
