Oil Sensor?
Oil Sensor?
Postby HZRDIZ » Wed Aug 25, 2004 9:59 am
Ok just wondering if there is such a thing as an oil sensir. The last couple of days my check engine light as been appearing after stop start driving every morning. Then i noticed the car was leaking oil and traced it back to the oil filter. Obviously this needs to be replaced or just tightened but does your check engine light come on for such a thing?
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
HZRDIZ
Postby Ae92typeX » Wed Aug 25, 2004 10:33 am
Im sure youve checked, but is your oil level still sweet?
It could come on if its got a leak around the oil sensor, thus reading an incorrect pressure.
Ae92typeX
Postby Mr Revhead » Wed Aug 25, 2004 3:01 pm
mate sort that asap... 4ages are notorius for running bearings if the pressure drops...
check your oil level immediatly
if its ok, check as above for leaks around the sensor, i dont think ae111s have a low level sensor, so if the lights coming on your damaging your engine.
if things look ok it may be something like sludge in the sump blocking the oil pickup, thats quite common on 4ages as well. what ever it is best you sort it before driving it!
Postby low_rider » Wed Aug 25, 2004 3:54 pm
what i think you should do is keep driving it and drive it hard!!!!
and if something goes wrong sort it out then sell it to me for 4 grand :lol:
rulk
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
http://toyspeed.blakjak.net/profiles/profile.php?id=336
low_rider
Re: Oil Sensor?
Postby matt dunn » Wed Aug 25, 2004 10:39 pm
HZRDIZ wrote:Ok just wondering if there is such a thing as an oil sensir. The last couple of days my check engine light as been appearing after stop start driving every morning. Then i noticed the car was leaking oil and traced it back to the oil filter. Obviously this needs to be replaced or just tightened but does your check engine light come on for such a thing?
If people read you post as you've explained it the correct answer would be..
The oil level and oil pressure sensors have nothing to do the check engine light. They will bring on the oil light but have no connection with the efi system.
You will need to check the codes to find your problem.
Not saying the oil leak isn't a problem, just not the problem you've stated.
Matt
Postby Mr Revhead » Thu Aug 26, 2004 10:57 am
oh.. he said engine check light.... i mis read that as oil lamp!m oh dear :oops:
Postby HZRDIZ » Thu Aug 26, 2004 2:15 pm
Mr Revhead wrote:oh.. he said engine check light.... i mis read that as oil lamp!m oh dear :oops:
Haha if the oil light came on id be screwed-checked the oil level last nite-im thinking it couldve been coming out the filter cause i put to much in cause it was reading over the full mark. Just me being paranoid really
HZRDIZ
