Apart from first thing on a cold start (until the oil pressure builds up) big end rattle usually relates to load. At 3000 rpm and throttle barely cracked open, there is hardly any load on the bearings, and the noise goes away. Let it slow down to 1500 rpm in a high gear, and then give it a bit of throttle.... that will load up the engine and should get your bearings rattling nicely
Cheers..... jondee86
sprint wrote:Has anyone replaced the big end bearings by just taking off the sump?
sprint wrote:Also ive got all the bolts off the sump but its still stuck on hard. anyone got a good way of getting the sump of the block?
Users browsing this forum: No registered users and 47 guests
