Bearings?
Bearings?
Postby sprint » Sun Aug 29, 2004 10:22 pm
Was out at puke today and on my last lap a rattling sound was coming from the engine. Tried to drive home but got about 20 mins along the way and deciede to get it towed. It seemed alright at about 2500 rpm as long as you kept a constant acceleration. On start up it rattles alot but once it settles down (3-4 secs) to idol it sounds ok. When the car is under load it also rattles. Anyone got some ideas on what this could be the car is a GZ20 Soarer with a 1G-GTE.
Old Rides:
88 GZ20 Soarer 1G-GTE
81 Ex Lancer
sprint
Postby fatgtr » Sun Aug 29, 2004 10:33 pm
does it get better when it warms up? if it doesnt possibly could be big ends.
James
gotta love the punk music
fatgtr
Postby sprint » Sun Aug 29, 2004 10:59 pm
Nah stays the same when its warm. Are there any other ways or things i can do to work it out? Like tell tale signs.
Old Rides:
81 Ex Lancer
sprint
Postby RedMist » Sun Aug 29, 2004 11:00 pm
It's big ends. Your hearing piston slap.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby sprint » Sun Aug 29, 2004 11:02 pm
So that means the engine will need to come out to fix it?
Old Rides:
81 Ex Lancer
sprint
Postby vvega » Mon Aug 30, 2004 7:25 am
means its time for a new one :(
v
vvega
Postby deaf_rattle » Mon Aug 30, 2004 8:44 am
pull it out, full rebuild
Postby sprint » Mon Aug 30, 2004 4:09 pm
Cant you change over the big end bearings by just taking off the sump?
Old Rides:
81 Ex Lancer
sprint
Postby kingcorolla » Mon Aug 30, 2004 5:07 pm
you can, if u are quite skilled, and u can get around the crossmember
1983 Carina AA63 4age
kingcorolla
Postby vvega » Mon Aug 30, 2004 5:51 pm
troublr id you wont be abile to clean out all the sludge thats in the oilways or in the head
its ok to change the bigend before they die like that
but to do it after is just asking for trouble
do it once do it right
v
vvega
Groundhog Day :)
Postby jondee86 » Mon Aug 30, 2004 7:51 pm
Apart from first thing on a cold start (until the oil pressure builds up) big end rattle usually relates to load. At 3000 rpm and throttle barely cracked open, there is hardly any load on the bearings, and the noise goes away. Let it slow down to 1500 rpm in a high gear, and then give it a bit of throttle.... that will load up the engine and should get your bearings rattling nicely
Cheers..... jondee86
Watch this space >>> <<<
jondee86
Postby sprint » Mon Aug 30, 2004 7:57 pm
Has anyone replaced the big end bearings by just taking off the sump?
Old Rides:
81 Ex Lancer
sprint
Postby matt dunn » Mon Aug 30, 2004 8:15 pm
sprint wrote:Has anyone replaced the big end bearings by just taking off the sump?
We did on our 1GGZE celica motor although they were done as a precaution after 2 race seasons and had not actually run a bearing.
Postby evil_si » Mon Aug 30, 2004 9:26 pm
if its knocking its not good, possibly spun a bearing, if a bearing has spun, crank will need a grind at the least, generally there $&#$%,
you can do a bearing roll in place, but if its spun or started to its pointless.
evil_si
Postby sprint » Mon Aug 30, 2004 9:49 pm
How can i tell whether or not it has spun?
Old Rides:
81 Ex Lancer
sprint
Postby sprint » Mon Aug 30, 2004 10:19 pm
Also ive got all the bolts off the sump but its still stuck on hard. anyone got a good way of getting the sump of the block?
Old Rides:
81 Ex Lancer
sprint
Postby kingcorolla » Tue Aug 31, 2004 5:33 am
sprint wrote:Also ive got all the bolts off the sump but its still stuck on hard. anyone got a good way of getting the sump of the block?
ye sumps can be a cuntt, coz of all that RTV. U need a sump cutter, which is like a blade u hammer inbetween sump and block, and hammer along, which would be hard if engine is in car now i think about it.
be rough, its just a sump, just make sure it seals when u finish.
kingcorolla
Postby sprint » Tue Aug 31, 2004 12:08 pm
So basically chisel and hammer around the edge
Old Rides:
81 Ex Lancer
sprint
Postby evil_si » Tue Aug 31, 2004 7:25 pm
use a plastic hammer and hit the sides of the sump, oor a big screw driver, try not to pry it too much, dont use a chisel u will $&#$% it.
there is no gasket as such just the silicon and its thick
you will know if its spun because when u pull of the cap the bearing wont come out, or if its bad the cap and con rod will be black from heat, use a torch and look for rods that are excessivly diferent from the rest in colour
evil_si
Postby sprint » Wed Sep 01, 2004 7:42 pm
Does anyone know what torque to tighten up the bolts on the conrods that hold the big end bearings? Engine is a 1GGTE.
Old Rides:
81 Ex Lancer
sprint
