MR2 Suspension
MR2 Suspension
Postby GTSMR2TURBO » Wed Sep 01, 2004 11:01 pm
Has any one found the MR2 rear suspension to be really crap cos mine just started knocking and creaking has any one else found this ???? :cry:
Current Ride - 1993 GTS MR2 (K&n pod, HKS bov, Toms Kit)
GTSMR2TURBO
Postby Al » Thu Sep 02, 2004 12:27 am
my rear suspension is fine, its perfect for what the car gets used for, dragracing. its 124,000km old factory springs and shocks 8)
Al
Postby Adamal » Thu Sep 02, 2004 7:56 am
If it's happening when you're going round a corner rather fast and gripping (as opposed to drifting) then you should probably replace the shocks.
Other than that, I think the setup is fine.
Postby Dell'Orto » Thu Sep 02, 2004 12:51 pm
Could be suspension bushes flogged out.
Mine is fine, but I have Ohlins innit
Re: MR2 Suspension
Postby Rollux » Thu Sep 02, 2004 1:36 pm
GTSMR2TURBO wrote: mine just started knocking and creaking has any one else found this ???? :cry:
Al found that the knocking stops if the susp arms are all tight....
Check to make sure nothing is loose or badly worn:, bushes, control arms, strut mounts etc.
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Rollux
Postby Mr Revhead » Thu Sep 02, 2004 1:52 pm
mmmm ohlins flash!
:lol:
Users browsing this forum: Bing [Bot] and 20 guests
