4AGTE wrote: but i have a delay when coming off the throttle of about 1 second.
Whether or not the pulley has something to do with this i do not know but you can’t buy a much bigger intercooler than what i have.
So i can’t really see the point of changing the set up to the degree that has been said here.
the fallen303 wrote:what is the throttle responce like on a stock setup map gze? does it still have the lag after throttle off? is it really as bad as you guys are talking about? what about changing the top mount air to air, to a water to air i/c? would this be better than running the factory air to air?
It really is as bad as we say, and the only way to stop it is to move the TB, and then run a nice big BOV to evacuate the excess air that is between the TB and the SC when the throttle closes.
Users browsing this forum: Bing [Bot] and 21 guests
