wil my stock 4agze computer fun engin fine if i.....
Postby event2 » Mon Sep 06, 2004 10:38 pm
jst wanting to no if standard 4agze ecu will handle me putting in blue top cams?
wat sorta power increase ya get with blue top cams in anyway? i jst gonne get them out of my old ae82 2 motor thats sitting in the shed.
but yea main point: how will they affect my agze rnning with blue top cams in? will it run at all?
ps: any one want any cheep cheep cheep bluetop 4age parts i got a motor full of emmm.
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby matt dunn » Mon Sep 06, 2004 11:27 pm
With a AFM is shouldn't make that much difference and so the ECU should be fine.
You realise that when you put in the cams you'll have to have all the tappet shims redone to get the correct valve clearance?
Postby event2 » Mon Sep 06, 2004 11:47 pm
nope didnt realize
i herd that its jst a straight swap with blue top cams.
its map sensor no afm.
its in a ae101 tureno
event2
Postby gdsup » Tue Sep 07, 2004 12:01 am
bluetop cams in my ze ran sweet, good for 200 hp at with standard pulley, u may have to do shims, but i didnt
gdsup
Postby EVLGTZ » Tue Sep 07, 2004 8:49 am
gdsup wrote:bluetop cams in my ze ran sweet, good for 200 hp at with standard pulley, u may have to do shims, but i didnt
I didnt either, just changed em straight over and no issues whatsoever
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby IH8TEC » Tue Sep 07, 2004 12:35 pm
hey evlgtz, has it made much difference? and where.
Postby EVLGTZ » Tue Sep 07, 2004 1:04 pm
IH8TEC wrote:hey evlgtz, has it made much difference? and where.
yeah think so eh, hard to compare power outputs as i've used 2 different dynos of late.
Seems to rev out a bit nicer now.
EVLGTZ
EVLGTZ
Postby Bazda » Tue Sep 07, 2004 5:33 pm
i also put blue top cams in mine, straight swap all clearances were within the correct tolerences.
made my car rev out better and reduced some of my lag.
Should run fine with yoru standard ecu. runs fine with my standard ecu but mines afm.
Postby event2 » Wed Sep 08, 2004 10:34 pm
cheer s all
event2
Postby Pelo » Thu Sep 09, 2004 8:17 pm
What are the differences between GZE/blue/red top cams?
Pelo
Postby Bazda » Thu Sep 09, 2004 8:46 pm
mainly the duration.
Postby Drifter4ag » Thu Sep 09, 2004 9:19 pm
uhhh ..
bluetop cames have .5mm more lift than ze/redtop cams
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Bazda » Thu Sep 09, 2004 9:25 pm
yea and that to
Postby 4AGTE » Fri Sep 10, 2004 8:52 am
SO when you put bluetop cams in do you use the 4agze pully's?
4AGTE
Postby EVLGTZ » Fri Sep 10, 2004 8:55 am
4AGTE wrote:SO when you put bluetop cams in do you use the 4agze pully's?
yep, nothing else is changed
EVLGTZ
EVLGTZ
Postby wanado13's » Fri Sep 10, 2004 4:32 pm
is the changeover from gze cams to bluetop ones hard, seeings as i know bugger all, do the gains warrant paying someone to put them in? cos i've got some in my shed and if it's worth it i might as well get them put in!
wanado13's
Postby Bazda » Fri Sep 10, 2004 4:54 pm
prob not worth the hastle if u gotta pay someone to do it, it's basically like doing a cam belt but a bit more work needed.
Postby FLAWLES » Fri Sep 10, 2004 6:38 pm
so there is only .5 of a mm or is this .5 of a tho
ha this has basicly answered my post i done at the start of the week
any1 selling blue top cams????
oh and bazda im still trying to get that price for you.... dont worry man i havent forgotin :wink:
FLAWLES
Postby Bazda » Fri Sep 10, 2004 8:25 pm
FLAWLES wrote:so there is only .5 of a mm or is this .5 of a tho
sweet as
