Remote Oil Filter HELP
Postby rollas22 » Tue Sep 14, 2004 11:36 am
needed a remote oil filter for my ae101 4age 20v turbo.
can anyone help with this??
KE-Corolla's for life!!!
rollas22
Postby GTZBOY » Tue Sep 14, 2004 1:36 pm
Grab filter and turn with your hand. If it is too tight, wack a screw driver through it and turn it off with leverage.DO NOT DAMAGE THE THREAD ON THE BLOCK...ONLY DAMAGE THE FILTER as you obviously dont need it.
Proud owner of an
S14 200sx
A 1992 Corolla
and 3 Kawasaki ZXR250c's
GTZBOY
Postby rollas22 » Tue Sep 14, 2004 2:11 pm
been there done that part. I need a actual remote oil filter adator kit kinda thing...
rollas22
Postby Dell'Orto » Tue Sep 14, 2004 6:12 pm
They're pretty readily available from most V8 shops I think, you know how the bogans love their braided hoses :lol:
Re: Remote Oil Filter HELP
Postby matt dunn » Tue Sep 14, 2004 8:19 pm
rollas22 wrote:needed a remote oil filter for my ae101 4age 20v turbo.
another trick if you are putting on a different manifold is you can remove the aluminum spacing block between the filter and the block.
If you need more space.
Postby atmosports » Tue Sep 14, 2004 8:54 pm
Down your way you'd be best to go to Etchell's or Brennan's, you'll need the oil filter remote mount + filter to suit, plus the hoses & fittings & then need a blanking/remote oil line take-off plate to bolt to the block where the standard filter was, you can add an oil cooler in the mix if needed as well. You don't need braided lines to do the job, Enzed should be able to supply you with suitable hoses & swagelock fittings to do the job or can make them for you.
atmosports
Postby rollas22 » Wed Sep 15, 2004 9:56 am
sweet. Looks like a easy plan
rollas22
Postby FLAWLES » Wed Sep 15, 2004 6:40 pm
i run a remote filter kit on my gtz " a v8 one if i remeber right " i do reckomend running braded lines as the extractors do run rather close to the lines
oil cooler would be good az well
FLAWLES
