by fangsport » Wed Sep 22, 2004 12:47 am
the ports were matched t the gasket, getting rid of the funny little square notch in the inlet, and virtually losing the bump in the exhaust.
if your head has the hole in the exhaust drilled, tapped and exiting from the combustion chamber, melt it down to make manifolds.
the 2/3T inlets can be easily adapted to interchange manifolds i.e 2Tb carbs onto 2tg, 3-t injection onto 2tg , i was using an avenger sidedraft manifold on my 3t as it came with the carbs and port matched (well, nothing a 12mm aluminim plate and a die grinder couldn't fix!!).
for huge bottom end, try a dual sycro 40/40 downdraft weber on an opened manifold, but make sure the fuel snout is secure to the carb body or your car will go on fire (not that i'd know, EH Matt)
