B_giB wrote:no, pedal dosent sink slowley to floor... its just spoungy
B_giB wrote:sweet, mite try that... how about removing all fluid first??? and starting from scratch??? or is it not recommened to remove all fluid from lines?
matt dunn wrote:B_giB wrote:sweet, mite try that... how about removing all fluid first??? and starting from scratch??? or is it not recommened to remove all fluid from lines?
Definatly not !!
You drain the level down in the resovoir but dont drain it all or you will have real drama's getting all the air out again.
