Fred wrote:yea i have pulled part 2 gear boxes now that were meant to be lsd!!! and they didnt have the hexagon ar through the middle. they ended up having 4 spider gears in the diff therefore not lsd.
2 of my mates oth with ae101 gtzs have lsd's, both with the hexagon ar through the middle and both u can spin 1 wheel and the other wheel will spin the same way.
vvega wrote:ok pulled the ae-101 gtz-lsd box apart
and the s/c mr2 box that i have
here we go
the diff that has what appears to be a solid centre has four spiders and is not a lsd
the diff that has the shaft in the centre is a viscous lsd
it only has 2 spider gears and a viscous coupling
the easy way to tell is the bar
also if you look at the splines in the in the box side of the diff
you will see it has 2 indipendent splines
this couples the viscous to the live live axel
i will have lots of pics later on
i took a hole heap
been a very expensive learning experance
there are also substantal differences in the mr2 and 101 internals
the mr is quite a lot beefer in every aspect
whilest the 101 has way better internal oiling and less internal loss
i have pics of the gearsets as well and these show the mr gearset is 1/2 as wide again per gear
and reverse and 5th is double the width
and the mr hasent got reverce synco unlike the 101
anyways i sould have some pics later
v
v
vvega wrote:lol
was more to explane why teh open diff didnt have a hex bar for th pinions
i thought that made it confusing
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
