Ingedients for it to scream
Postby mr bmw » Wed Oct 06, 2004 11:21 pm
another plan on the board for the starship make-me-rise (haha)
really high reving 4k/5k.
what is the recipe up you can show me bearing in mind i only need ideas to get prices etc at da mo
cheers for the help ladies and gents
mike
APPARENTLY, THE WORD "NON-FLAMMABLE" IS NOT MEANT AS A CHALLENGE TO ME... HUH, LEARN SOMETHING NEW EVERYDAY!
mr bmw
Postby kingcorolla » Thu Oct 07, 2004 12:27 am
for a k series..
-BIG porting
-10:1 CR (this can be done by replacing head and pushrods with previous generation engine eg. 3k head on 4k etc.
-reground cam
-extractors, exhaust etc
-ramflow filter or similar
selection of carb options, downdraft or SIDEZ!!! An easy way to upgrade to twin downdraft carb, is to find some off a 3k-b, they floating around. KE25/35 had them. or you could do what i did on my old 4k, get a mainfold from kelford and chuck some twin 45mm delorto SIDEZ. Therz a few options available, some keeping factory manifold, and getting an adapter plate made to mount foreign carb on factory intake manifold
If u really want to keep going thers other things like lightweigt rods/rockers, and a electronic ignition upgrade from KP62 starlet can prove effective in more accurate timing etc.
Good thing about k series engines is that they r so basic and easy to work on 8)
1983 Carina AA63 4age
kingcorolla
Postby oldskoolboy » Thu Oct 07, 2004 2:07 am
kingcorolla u seem to know a lot about 4ks, can you tell me what you ment by "extractors" ?
sorry im a fresh noob with lotsa questions :oops:
nothin is better than my ke35 :)
oldskoolboy
Postby Zak » Thu Oct 07, 2004 2:54 am
Zak
Postby Rollux » Thu Oct 07, 2004 12:33 pm
Rob's original 4k in his starship would rev all day to 8 without being stressed, 9 if you were angry. Alas, it now sits on the floor looking pathetic next to the mighty SR20DET.
His had
Ported and planed head with oversized valves
Flowed intake mani (with twin Sidedraft dellorto 40s)
Flowed headers into 2.25" exhaust
A cam so big that it won't idle under 1700rpm
Lightened flywheel mated to 5speed box
New pistons and ring set(standard from ACL)
No power under 4000rpm, but very quick if kept above. And it sounded glorious.
Going into a KE20 now.
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Rollux
Postby Mr Revhead » Thu Oct 07, 2004 12:36 pm
no point putting the factory twin carbs on them, the manifold desing means it only sucks from on carb throat at a time, and the twin carbs are smaller than the one card set up. you really need a better manifold and some side draughts!! or i could sell you an injection set up!
injection on its own doesnt make much mor epower but i think the torque is better
Postby Lloyd » Thu Oct 07, 2004 3:04 pm
Might wanna chuck some decent valve springs in there too. They may seem like they'll be right up to about 7500-8000 but I wouldn't be trusting them.
Do it once, do it right
Postby matt dunn » Fri Oct 08, 2004 8:30 pm
HRT wrote:Might wanna chuck some decent valve springs in there too. They may seem like they'll be right up to about 7500-8000 but I wouldn't be trusting them.
STD valve springs wont do much more than 5 - 6000 rpm
Postby Mr Revhead » Sat Oct 09, 2004 9:06 am
fit a 2k .... good for 170kmh 3 up in a kp60 :wink:
Postby mr bmw » Sat Oct 09, 2004 12:59 pm
how many cc is the 2k??? 3k???
4k is 1300cc
and a 5k 1500cc.
correct me if im wrong
mr bmw
Postby z|gen » Sat Oct 09, 2004 1:50 pm
2K = 1000cc
3K = 1200cc
4K = 1300cc
5K = 1500cc
7K = 1800cc - fuel injected
AE91 SUPERCHARGED COROLLA
z|gen
Postby mr bmw » Sat Oct 09, 2004 2:44 pm
thanx heaps, definatly go for the 4k now
heaps easier to come by!!!
mr bmw
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
