4K Carby Question
Postby Mr Revhead » Wed Oct 20, 2004 11:09 am
probably too big for a stock 4k, at the very least it will need to be re jetted
Postby Mr Revhead » Wed Oct 20, 2004 11:15 am
by re jetting i mean replaceing the jets with ones that will suit your engine, how modded was the other engine? you could try it and take it to a mechs and put it on the gas analyser to see if its close enough.
dont bother with a ram flow get a k&n or similar, ram flows shoudl be left on cortinas
Postby kingcorolla » Wed Oct 20, 2004 1:10 pm
just go for it pervert. ill tell you from experience that itl be fine. May run a bit rich but thats fine. you will notice gains.
i just fitted a 2L carb from a cortina onto a 4k. and fitted extractors and a ramflow aswell. the gains were good up top, but thats were all the power is on modded 4ks.
My old 4k had sides on it, and a big fuk-off cam and it wouldnt idle below 1000rpm, but wen it hit 4000rpm, it was great.
And what u got against ramflows warwick?? INDUCTION noise bro!
1983 Carina AA63 4age
kingcorolla
Postby Mr Revhead » Wed Oct 20, 2004 1:26 pm
haha ramflows are about the worst "filter" around
Postby Mr Revhead » Wed Oct 20, 2004 2:49 pm
go weber, more bits and info around for them
Postby fangsport » Wed Oct 20, 2004 7:10 pm
go weber. very easy to tune and no unnecessary emiisions crap to deal with. easy to build adapters for them as well
fangsport
Postby kingcorolla » Wed Oct 20, 2004 7:38 pm
pervert wrote:Where did you source the extractors from kingcorolla?
Is the carb you fitted a webber 32/36 DGAV from the Cortina? I can get on of those as well, which would be better?
ye thats the one i think. Which one? well it all comes down to the amount of mods you do. if its pretty standard, a big carb will not be as effective. If your going to fork out on the thing, get some sidedrafts :P
if you are gonna be muckin around with the manifolds, can i suggest some headwork? to get the most out the carb/(extractors?) headwork is money well spent. Its all willing on how much you are prepared to spend.
if your budget is low, just get some porting done. wanna spend a little more, buy a 3k head and port that. More? angle valve job. etc etc.
k series manifolds are cuntty and are best to work on once if possible.
and the extractors..? Pm me
kingcorolla
Users browsing this forum: Google [Bot] and 33 guests
