timing probs...
timing probs...
Postby ris4ray » Tue Oct 26, 2004 5:36 pm
can someone here explane how to change the timing on an 84 corolla with a 4a motor ... please[/quote]
ris4ray
Postby Lloyd » Tue Oct 26, 2004 6:04 pm
You'll be needing a timing light to set it properly. Should be 2 bolts around the distributor which if you loosen off will allow you to turn the entire distributor around which will change your timing.
