suitable radiator for a 4age
Postby l1ttle_d3vil » Fri Oct 29, 2004 9:01 pm
what would be the best sort of radiator to use with my 4age (in a ke35 if that matters)? will a standard radiator from a 3k be OK? ive been told both yes and no :?
ive also been told to use a 3 core radiator as opposed to a 2 core radiator (which is what the one of the 3K is)...
Postby KinLoud » Fri Oct 29, 2004 10:23 pm
The standard 4age radiator is quite small and only single core.
It looks exactly the same as ones you find in a 3a powered car.
This is based on my AA63 4age Carina and 2 AA60 3A Carinas.
Ken
Hamilton
021 408 863
Postby ChaosAD » Mon Nov 01, 2004 5:47 pm
What would you recommend for a worked 4age?
ChaosAD
Postby NZ_AE86 » Mon Nov 01, 2004 6:13 pm
Your 3k radiator will work well but your plumbing might be easier if you get one with the pipes on the correct side. :)
Factory 4AGE Radiator works fine for high Hp 4AGE's. :D
NZ_AE86
Postby Stealer Of Souls » Mon Nov 01, 2004 6:33 pm
Avoid an Auto radiator.
I think that small difference in internal capacity makes my 4A a little tempermental with temp... See if I turn my heater to hot then I never overheat, turn it to cold, start overheating if I drive long enough...
Just a theory...
'86 AE85.5 Levin
Stealer Of Souls
Postby spencer » Mon Nov 01, 2004 6:58 pm
Stealer Of Souls wrote:Avoid an Auto radiator.
Just a theory...
Hmmm my auto radiator is exactly the same as a manual which is the same as most single core ae86 ones. Maybe your problem is something else?
ms63 crown
spencer
Postby l1ttle_d3vil » Mon Nov 01, 2004 9:40 pm
NZ_AE86 wrote:Your 3k radiator will work well but your plumbing might be easier if you get one with the pipes on the correct side. :)
thanks for the response. the plumbing isnt a problem, as i can get someone to change it around without any trouble. may have found a bigger radiator which will do the job now anyway.
