TRDWGN wrote::lol: How can a 20v bottom end be described as weak when compared to a ZE bottom end? Really the only obvious difference is low comp pistons compared to high comp pistons....
ke70wagon20v wrote:TRDWGN wrote::lol: How can a 20v bottom end be described as weak when compared to a ZE bottom end? Really the only obvious difference is low comp pistons compared to high comp pistons....
spot on, this mod would be a waste of time not many 20v's n/a are gunna smoke pistons so whats the point? plus you loose the cut outs for the valves and the correct piston dome for compression, so you would have to shave half the head off/deck block to get compression back up
vvega wrote:ke70wagon20v wrote:TRDWGN wrote::lol: How can a 20v bottom end be described as weak when compared to a ZE bottom end? Really the only obvious difference is low comp pistons compared to high comp pistons....
compleately incorrect
20v head is a bolt on to a ze bottom
just makes it a interferance head
im look ing at a blacktop head on a xe bottom right now
massive hp has been proven many times from this combo
and massive has been done teh 16v way
at the end of the day its your choice
v
v
CozmoNz wrote:Um, 4agze bottom end, forged pistons, rise compression ratio to 10:1.
4age 20v blacktop head, port head, obviously custom intake manifold to qtb, remove trumpets, runing around 8psi? with lightened flywheel etc, good responce, *enough* power without boost, then more when boost hits.
Users browsing this forum: Bing [Bot] and 22 guests
