Engine vibration issue, 1996 BZ-G Levin
Postby Graphite » Wed Dec 15, 2004 8:24 pm
Recently I have had a bit of work done on my car, I had the cambelt done 3000k's ago and just last week the clutch replaced.
The problem I have was evident before clutch replaced though, have noticed it more since driving another car around for a few days.
When I cold start car in the morning the whole car vibrates quite noticabily (when the revs are up), when the cars warmed up and at normal idle RPM it seems ok, but if i slowly increase RPM to 1200 it vibrates heaps again, it seems to be between 1200-1500rpm, at high RPM its fine.
Anyone have a clue what could be wrong?
Thanks in advance.
Graphite
Postby THA SHZ » Wed Dec 15, 2004 9:44 pm
Is it wen just under slo acceleration ? Have u checked ur engine mounts ?
THA SHZ
Postby Graphite » Thu Dec 16, 2004 8:55 am
THA SHZ wrote:Is it wen just under slo acceleration ? Have u checked ur engine mounts ?
Its only from 1200-1500rpm when you are sitting parked, not in gear etc.
Do these engines have counter balancing shafts etc that need to be set properly when changing cambelt?
Graphite
Postby CozmoNz » Thu Dec 16, 2004 1:15 pm
Lanius wrote:If you suspect engine mounts, watch your gearstick when you accelerate and then brake. If the gearstick moves around excessively without you touching it, then your engine mounts could well be on their way out.
so if she wobbles like a rwd :P its the mounts :)
Rayne For President!
CozmoNz
Postby BlakJak » Sat Dec 18, 2004 12:14 pm
Heh
In an Auto its harder to pick
but my engine mounts are buggered, and I have vibrations up the wazoo
waiting on parts ex japan to get em done :|
BlakJak
