4AGZE Alt
4AGZE Alt
Postby CAMB01 » Sat Dec 18, 2004 2:13 pm
Is it possible to run the Alternator on a 4AGZE if you don't have power steering or air con, if so how would i go about it?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby CozmoNz » Sat Dec 18, 2004 2:40 pm
attach belt to alternator pully... attach belt to crankshaft pully....
what else is there?
just find the right sized belt, the ratio will be the same if the pully remains the same size.
Rayne For President!
CozmoNz
Postby 3T-Rona » Sat Dec 18, 2004 4:01 pm
i think he means minus the mounting points (assuming they r on the a/c assembly) ive got a 4agte no a/c or p/s and ive got a custom made mount that relocates the alt to the plenum side.......
3T-Rona
Postby ATAl » Sat Dec 18, 2004 6:15 pm
are you keeping the supercharger? If so you'll need some custom mounts or at least some custom idlers, if your going turbo you can just use the non-supercharged alt mounts.
ATAl
Postby CAMB01 » Tue Dec 21, 2004 9:50 pm
bump
CAMB01
Users browsing this forum: Bing [Bot] and 29 guests
