Al wrote:$5k? buy an mr2 turbo , sell the wagon and use what you get for it on mods, run 12s
vvega wrote:single turbo converion to vf22
link ecu
zorst system
front mount
bov
done
Silent Knight wrote:and what vvega has just quoted will be very reliable.
turbo conversion done properly will be just as reliable as the setup you have stocers.
ecu can only help you in a positive way if you tune the car properly as it will run more eficiently.
FMIC and Zorst will by providing allot better flow.
and BOV.....work it out for yourself.
Silent Knight wrote:Yes, it can all be easily done for 5K and you wouldn't really need any other mods to support it. You can look at changing the fuel pump and injectors etc when you plan on running higher boost and need more fuel otherwise you don't need to upgrade those.
Silent Knight wrote:I'm not entirely sure on the stock boost of these cars but I am guessing around the 10-11 psi mark.
What sort of boost you run after everything is done is depending on a couple of different factors. Internal/External wastegate, what the ecu is configured to do, wether you have a boost tap or not, flow of the IC etc etc
Silent Knight wrote:well if you just want it to run very reliable and be a gud ride then i suggest just going for the ecu, zorst, intake and mbe intercooler.
spend the rest on suspension so you will hve a better ride.
that way she stays very reliable and you will enjoy driving it.
Lunchie wrote:why should i get an ecu i mean if im not going to play with the boost at all how will it help i mean can u actually get decent power gains from a turbo car by fitting a new ecu without winding up the boost?
pervert wrote:Lunchie wrote:why should i get an ecu i mean if im not going to play with the boost at all how will it help i mean can u actually get decent power gains from a turbo car by fitting a new ecu without winding up the boost?
From a chip, yes you can get power gains without touching the boost...
Dr-X wrote:Factory computers are very conservative, and there are very decent gains to be made with a decent aftermarket computer. And I would stay away from 'chips' if you can afford a whole new ECU.
