help needed urgent
help needed urgent
Postby cr1mnl » Thu Jan 06, 2005 5:55 pm
is it possible to adjust the brake balance on the rear of a ae101?
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby vvega » Thu Jan 06, 2005 6:01 pm
why woudl you want to ??
v
vvega
Postby evil_si » Thu Jan 06, 2005 6:05 pm
i take it still didnt pass?
it is a 1995 ae101
the car has a rear brake imbalance,
on the foot brake the left rear is a lot higher than it should be,
evil_si
Postby Dr-X » Thu Jan 06, 2005 6:06 pm
Rebuild both rear calipers - cheap, easy, and will probably solve your problem.
Dr-X
Postby vvega » Thu Jan 06, 2005 6:10 pm
unless its you rear biasing valve then you would have just wasted all the money to get teh same result
are the leacking ??
do the have good pads ??
do they lock up evenly when you apllie the hand brake ??
do you have abs ??
need a liitle more info :D
v
vvega
Postby Dr-X » Thu Jan 06, 2005 6:11 pm
vvega wrote:unless its you rear biasing valve then you would have just wasted all the money to get teh same result
They're cheap to do, and it's good general maintenance anyway.
Dr-X
Postby evil_si » Thu Jan 06, 2005 6:21 pm
no not leaking, no abs, and yes hand brake passed brake roller test ok
evil_si
Postby jacko » Thu Jan 06, 2005 6:35 pm
Flat mates ae111 just had same problem - was the valve $$$
lickem.
jacko
Postby vvega » Thu Jan 06, 2005 6:35 pm
id be heading towars biasing valve
there not to cheap but pm ken loud he might have a spare :D
v
vvega
Postby fangsport » Thu Jan 06, 2005 8:21 pm
are the lines in good nick?
no kinks or dings in the metal line, obviously the rubber line is okay 'cos they would have failed it if perished.
looks to me like a valve issue if the handbrake pulls up evenly.
fangsport
Postby cr1mnl » Thu Jan 06, 2005 9:02 pm
cheers for help. like si said pads are new, no leaks, no abs, handbrake is pulling up evenly on the rollers. imbalance is almost 50% left rear reads about 150 right is around 100 on the foot brake. may have to shoot to pick a part and get a balance v/v. car only has till to the 9th to get re-checked so need to get it sorted
www.ology.co.nz
cr1mnl
Postby CozmoNz » Thu Jan 06, 2005 11:49 pm
mines doing this, but its on the rears so i didnt really care ^_^.
i just took it to another place, so its the valve or something, how much is one, where is it fitted etc, INFORMATION please :).
Rayne For President!
CozmoNz
Users browsing this forum: Google [Bot] and 31 guests
