Will ae86 steering rack fit on Ae70?
Postby spencer » Fri Jan 07, 2005 6:19 pm
yea if the ae85 or 86 x-member is used aswell I have a few racks pumps and lines around if you get keen
ms63 crown
spencer
Postby MetalupYoAss » Sun Jan 09, 2005 1:09 pm
yes; provided your original system is rack n pinion, if its recirculating ball the ps collum wont fit properly but i think you can get aroud it by drilling some holes
MetalupYoAss
Postby spencer » Sun Jan 09, 2005 4:53 pm
good point fogot about the non rack n pinion *e70's
ms63 crown
spencer
Postby fangsport » Sun Jan 09, 2005 7:41 pm
arn't the power racks a bigger diameter to the non power units and require the appropriate x-member?
fangsport
Postby spencer » Sun Jan 09, 2005 9:57 pm
yea thats sort of what I was meaning to say but it never came out if you want to use power steer use the PS ae85/6 corresponding x-memeber aswell. The powersteer rack has a larger diameter and therefore bigger brackets. also the coloums are different from PS to non PS but something could be modded easily
ms63 crown
spencer
mags?
Postby rwd_mayhem » Tue Jan 11, 2005 4:14 pm
fully off topic, but what are those mags in your avitar? they r always on ae85/6's.
current: 1975 Valiant Regel
rwd_mayhem
