GTZ not starting...
GTZ not starting...
Postby alastabesta » Fri Jan 07, 2005 7:04 pm
The other day trying to start the GTZ and found out the battery's completely dead (no lights at dash even). Thought oh well, haven't driven the car for almost a year, should be dead anyways, got the AA guy and jump started, left it on for 30 mins and went for another drive to charge the battery. The next day its dead again, COMPLETELY dead...
anyone know what could be causing this problem? It was completely fine last time we drove it... back in april last year or sumthing...
2001 Caldina GT-T
alastabesta
Postby Silent Knight » Fri Jan 07, 2005 7:12 pm
It could be your alternator being bung or it could be that you just need a completely new battery.
Had the same problem with my supra and it was because the battery was completely $&#$%. Charge it for like an hour and go for a drive but once it's turned off you can't turn it back on.
Try using a new battery with it and see if that helps otherwise it might be your alternator.
Silent Knight
Postby cr1mnl » Fri Jan 07, 2005 7:48 pm
battery is rooted
you could try leave it on slow charge overnight on a charger but most likely will need a new 1
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby EVLGTZ » Fri Jan 07, 2005 8:09 pm
got a charger u can borrow if need be Andy
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby alastabesta » Fri Jan 07, 2005 8:59 pm
sup man
i took out the battery from my car and vrrrmmm it went but smoke came outta a silver unit next to one of the 4 exhaust pipes!? the one on the far left... and I could see the exhaust wrap on that particular one is in dark coffee colour...but i checked the engine oil and its full still... no idea whats wrong with it...
close up of the unit
anyone got any idea what on earth that unit is and why its burning when i turn the engine on...?
thx all ^_^
2001 Caldina GT-T
alastabesta
Postby EVLGTZ » Fri Jan 07, 2005 9:20 pm
ooo crank angle sensor. no idea why that is smoking. Shouldnt be. Maybe shorting out for some reason? Might be somethign dodgy u knocked when changing batterys over?
EVLGTZ
EVLGTZ
Postby alastabesta » Fri Jan 07, 2005 10:42 pm
nah man
battery's in the boot ^^
brother done the battery relocation cos of the intake system...
what does the crank angle sensor do by the way...?
2001 Caldina GT-T
alastabesta
Postby IH8TEC » Fri Jan 07, 2005 11:54 pm
it is to adjust the timing. most cars use a distributer and they turn that. because of the coil packs, they use the crank angle sensor, does the same job.
Postby alastabesta » Sun Jan 09, 2005 11:53 am
problem fixed. thanks guys :)
2001 Caldina GT-T
alastabesta
Users browsing this forum: Bing [Bot], Google [Bot] and 49 guests
